1800?
no_cones_ever
anyone in the mood to sell an 1800 to a kid who needs it(not really "need", more like want)
If you weren't so far away....
stockton CA, and i am looking for specifically an 1800 to put in my Mk2 sprite
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]i am looking for specifically an 1800 to put in my Mk2 sprite [/QUOTE]
No need to look any farther - it won't fit!
what needs to be cut to make it fit...a smallblock will fit in it...i have seen a hemi in a bugeye...
You'll need to add about 3 inches to the height of the hood & lengthen the engine compartment by that much or more...& the transmission tunnel will need to be about 5 or 6 inches wider.
It's not just the size of the lump, it's the shape. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
R.
A good choice, though, is any of the Ford "Kent" series of pushrod engines.
You should be able to find a 1500cc or 1600cc version not too expensively, though the Formula Ford guys have used up a lot of the blocks.
What's good about them?
1-Short stroke, high revving, big valves, not too tall so they fit well.
2- 5 bearing cranks, tough and smooth running.
3- Relatively light, closer to an A series than a B series in weight.
4- Very slick full synchro box.
Back in the 1960's a friend of mine had 1300cc Kent in place of the 948 A series in his frogeye Sprite, and it was a huge improvement.
Simon.
A guy can have alot of fun with a 1275 and you can spend your time and money making a killer engine, not making an engine fit, then having to spend more to build the engine.
I agree and if money is an issue a 1275 with the other necessary upgrades:
1. hold you over for a while on speed, since they move pretty well.
2. be a quicker install, so that you can get it on the road sooner
3. provide good reliability
4. not be a structural issue
5. give time to do other upgrades, brakes etc.
6. be modified in the future to provide about 100hp, remain reliable and street drivable.
lastly it maybe more accepted by some of our trueist.
Patrick
I guess the question then becomes- "Where do I find a 1275cc A series?"
Wish I could help you- but I'm sure others here have the answer.
Sorry, I had to scrap a bunch of em when I lost my storage, two years ago.
I am sure that others here can help.
Patrick
