[ QUOTE ]
Michalotti,
How did you adapt the 5 bolt pattern for your Bullit wheels to the 4 bolt Triumph hub?
[/ QUOTE ]
Used a two-piece adapter, it also helped with the offset issue on the Bullit wheels. Since I got a good set of 245/45R17 tires included with Bullit wheels, I had to use a two inch adapter at the rear to insure clearance of the trailing arm. This then means the tires will stick out beyond the fender lip.
