Bruce_B
I'm going to be replacing my 1098 engine in my 59
BE with a 1275 engine, using the same ribbed transmission that's in the car.
Came across this online, Bottom line is do I have to make modifications as stated to fit the 1275? Thought it was a straight swap? Just wanted to confirm that he's talking about a smooth-case transmission....thanks.....
-Also can I continue using my single brake/clutch cylinder?
"For more torque and horsepower, the early model engines and gearboxes could be replaced by 1098 or 1275 engines and gearboxes with no other modifications needed. However, if a 1098 or 1275 engine is fitted to a Mk 1 or 2 gearbox, the bell-housing must be ground out to clear the new clutch. Also, the carbon thrust and clutch release fork to suit the engine must be fitted to the bell-housing in order to get a fully operational clutch. As well as this, the 1275 diaphragm clutch must use the 1" bore clutch slave cylinder as fitted to the 1275 engines - for a correctly operating and long-lasting clutch. (The 1275 split master cylinder set-up should also be fitted - or the hydraulic line adaptors used."
Hi Guest!
