1275 Transplant --- Final Report
Pythias
Last weekend I took a trip to Astoria down US 30, a 100 mile round trip. The engine performed as well as I could have ever hoped. Passing uphill without having to get a run to get a head of steam was not necessary. Regular two lane passing just by hitting the gas, again, no run necessary. 30 mpg. ...
Friday night I set the valves, (with feelers as recommended) and Saturday morning drove up to Fife. Running at 60 mph for 100 miles I got over 40 mpg. For the round trip of about 200 miles, my average was about 34 mpg. The second tank included a trip to the LeMay museum (do that if you can!) and the run home, about 1/2 of which was 70 mph and showed 28 mpg. At an ambient temp of about 55 degrees, the car runs at 170 degrees, 68 psi oil pressure at 70 mph.
Suzanne commented that the car is now much quieter (i.e. we can actually talk without having to yell) and she thought that the ride had improved. Maybe the new seat cushions have something to do with that.
Overall, I now count the swop complete and a complete success.
One more oil change in another 700 will be my second oil change so that I have one at 500 miles and one at 1500 miles. I plan to change again at another 1500 miles then go back to a regular 3000 mile interval.
bug_sixty
Bet you enjoyed those twistees just before Astoria! Great route.... Have you ever been up the WA side? It's special too
Billm
Glad that it is working well Bill!
Come on down and we can see if you can catch me :smile:
Glad to hear that Susanne is still in the picture.
BillM
Pythias
Pythias
I make the drive just so that I can do those Esses. It was one of the very few times that I had them clear shot at them, at least going in. I DO sometimes make the circle route and go down the Washington side and back up the Oregon, or vice versa.
Pythias 1275 transplant progress. Spridgets 50
George Zeck 1098 v. 1275 engine transplant ?? Spridgets 13
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
