108 octane....
macino62
Drove down to southern Indiana today to go look at a BSA. On the way home, I stopped at a gas station about 20 miles from my house....they had 108 octane fuel for sale. Only $4 a gallon!
jerrybny
I'm not sure my TR6 would know what to do with any octane over 93 other than to burn a hole in my wallet. Now if I still had my 69 Firebird it would surely like it.
macino62
macino62
i think my turbo-charged TR4 will like it *muwhahahaha*
Simon TR4a
At the local race track they sell Sunoco, I think one unleaded at about 107 octane and leaded at somewhere over 110, but the price is $3.25 a LITRE! (3.8 litres per U.S. gallon)
I would think that as it is for race use there would be no government highway tax, like fuel sold in marinas or diesel for agricultural tractors, but perhaps the distribution costs are high because of the small quantities sold.
Simon.
Russ Austin
Hey macino62; Where in Southern Indiana was the BSA, and where are you from.
G
You would need much higher compression ratio to take advantage of the high octane fuel. I think the average US TR can run well on 87 octane, unless you get too much pinging, then you might bump up to 89. I run 93 octane only because my car has been bumped to 9.5:1 cr from 7.5:1.
macino62
macino62
correct, there would be no benefit to using 108 octane in a low compression, normally aspirated car. I ran a couple of tanks of 100LL av gas, and noticed no real difference (except a lighter wallet).
forced induction needs the higher octane levels to prevent detonation. higher octane and intercooling should add about 10 hp per psi. (IE: if I'm running 5 pounds of boost in my TR4, it's not unreasonable to expect an increase of 50 horsepower). I used to have a Porsche 944 Turbo which ran 13 psi from the factory. I replaced the EPROM with an 18 psi chip. There are current chips that allow 25 psi, without fear of overboosting.
I'm about to put an end up my turbo-charging project, and focus on the FI/ITB/Megasquirt project.
J Need steering bearing assembly 129-108 Triumph 1
tr6nitjulius General TR Petrol Prices & BC 94 octane Triumph 7
T Caffeine and Octane TVR 3
Lin 110 octane fuel Austin Healey 24
T Selecting octane levell for new engine build[?] Spridgets 7
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
S Correct Octane for BJ8? Austin Healey 12
AH67 Octane Boosters...what is the common wisdom Austin Healey 7
dougie Octane Maginzine July 2012 Austin Healey 4
arizonamike Octane Booster Triumph 13
M Fuel additives and octane Spridgets 32
Burrell22 Octane Rating Triumph 20
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
V Octane magazine: Midget is 1 of the top 10 cars! Spridgets 8
G what octane? Austin Healey 23
N Thoughts on compression ratio and fuel octane??? Spridgets 3
R Octane levels - engine pinging Austin Healey 4
C lotus 9xx engine Compression on 91 octane Lotus 3
angelfj1 Octane Boosters - Has Anyone Mixed their Own? Restoration & Tools 5
JamesWilson Octane Magazine Lotus Issue Lotus 4
tony barnhill MGB Gas Octane for MGB's MG 47
hondo402000 TR6 Octane boost for your TR6 Triumph 12
MTribe how octane affects streetable compression ratio? Triumph 18
A Timing or Octane? MG 3
B Electrical problem / Fuel octane MG 12
S Lead or octane boost? Austin Healey 3
10musketeer Learn me something=Octane+timing Spridgets 11
I TR6 TR6 Octane Outcomes? Triumph 3
jerrybny Octane Poll Triumph 9
G high octane? MG 31
JamesWilson Octane Magazine- Rally Healey Cover Story Austin Healey 1
Editor_Reid 110 Octane Austin Healey 11
Shane Seen on Octane's website... Austin Healey 2
aeronca65t 100 Octane Fuel Restoration & Tools 12
Y Octane Magazine Article Austin Healey 1
Bruce Bowker Octane Magazine Austin Healey 2
J octane Restoration & Tools 2
