100/6 vs 3000 driving experiences
tdskip
First of all-a sincere merry Christmas to everyone. I hope the holidays have been full of warmth and family.
My long-distance touring codriver and I are considering a big Healey for our next car. We are planning to enter a number of the 1000 mile events this spring and fall, these are fast road events where reliability is super important and the car has to be capable of hanging with much more exotic and high-speed touring cars (yeah, Ferrari stuff).
We are starting to narrow our choices down to a100/6 or later 3000. I know the cars got more weather protection and a always fitted top as they progressed through the years. Having some wind/weather protection on an event like this is obviously a plus, but these are generally sunny in moderate temperature events anyway.
I was hoping to get some coaching from you all on if these two would drive significantly differently or if they would have very similar driving dynamics with the wi d/weather protection mainly being the big difference.
Thanks!
steveg
If you're planning on the California Mille, it's limited to cars that could have run in the MM which last ran in 1957. Not sure about the Colorado Mille or others. You could maybe get by with a 100-6 with the 12 port head.
All the 6-cyl cars have similar suspension except for the Phase II BJ8. Udo Putzke's Bilstein shock kit makes them ride better.
If the events will let you use a late BJ8, suggest air conditioning it as well.
T
tdskip
Thanks for the response Steve. Age cut off is a good consideration.
Sounds like the tweaks are very similar for both?
John Turney
Yes, the age cutoff is a definite consideration. A 100-6 with the 12-port head and 4-wheel Dunlop disc brakes ran in the last (1957) MM. Forum member Dougie is also a proponent of the 100-6. I''ll let you know in a few months how air conditioning in a 100-6 works out.
T
tdskip
Hi John-hope you're having a good holiday season. Thank you for the response.
Now that this is been stated it seems like a fairly obvious consideration. The immediate event that we're looking at is 73 or older, but if I'm going to buy/build a car up for one of these events I might as will make sure it's eligible for all of them .
elrey
You will need a four or five digit number to date the bn4's. The high compression six port engine was built starting in Oct of 57 when they changed from the gallery head [integral manifold] to the head with a separate one piece intake manifold. Between Chassis/Engine 48863 and 52602 the gallery engine was intermixed with the separate intake engine. The last 1957 was c/e 54285, the last car built at Longbridge. This info. is from Anderson and Moment's Austin Healey 100/100-6/3000 Restoration Guide. I hope it is of some help, happy hunting!
elrey
The separate intake manifold engines [26D] installed at Longbridge were painted silver green but some [26D] engines painted the dark olive green used on Morris engines have been found in early Abingdon built cars. Cars were built concurrently at both locations between Nov. 57, and Dec.57, when production ceased at Longbridge and continued at Abingdon. Same info source as above.
T
tdskip
Thanks.
The engine in the car as of six port with the dark or nonmetallic green.
Here is what I have;
VIN: BN4L030660
Engine Code: 26D/U/H 53917
elrey
The vin [BN4] means occasional 4 seater. The [L] means left hand drive. The [O] means equipped with overdrive. The engine code [26D] means separate intake engine. The floor shift. The [H] high compression. Apparently there is also an [R] if the transmission was equipped with overdrive. Also.... in order to track production of BN4's at Abingdon a separate "Abingdon Allocation" number was assigned sequentially, running from 501 to 4741. this allocation number was shown on a stamped plate extending below the car number plate, secured with the same screws. [This may be the number 730 that you referred to earlier.]
T
tdskip
Thanks, new to Healey VIN and engine codes.
Engine code looks like in the range for '57?
How to read the numeric part of the VIN? I don't see how to match that up?
Sorry if I am being dense.
elrey
Dense you are not. The Healey folks leapt around with their number codes and it is kinda screwy. Perhaps they did it to keep the tax man at bay. Some times the engine code matched the chassis... some times it did not. Engine code and Morris engine color lead me to believe that this engine was an early Abdingdon installed engine. The chassis number is pre 58 and if the number 730 is on a plate below the vin then it stands to reason that it is an early Abingdon production auto. There are some registry sites here in the Austin Healey section where you might find neighboring autos from which to divine the placement of this car in question. The beauty of this forum lies in the fact that surely someone with greater knowledge will be along within a few days to set us straight. :cheers: Perhaps the car is an earlier 57 chassis with a later 57 engine. With all the movement of location, parts, books and personnel any combo may have occurred.
DerekJ
The car has a replacement engine. BNL030660 is an early Longbridge car which would have had an integral manifold. The engine in the car is from BN4 53917 which had 6 port head and which fits in the short period when the engines were painted the Morris Green colour.
elrey
The cavalry has arrived! ... Aha! ... The old replacement engine trick! ... Thank you DerekJ. And perhaps due to the lack of an [R] in the engine code the engine donor car lacked overdrive. I wondered about that.
T
tdskip
Good mornings, thanks both for the reply and your site (great resource).
As an early Longbridge car that means pre-1957 so I think I am good there.
How big of a deal is the replacement engine on values and eligibility? I use my cars so not overly concerned about getting dinged at a show by a judge but want to be eyes open about it. She is a moderate restoration so no way around it consuming a fair amount of money and would be keen on everyone's thoughts as to impact on value.
I doubt that the touring events I am planning on running will car about the replacement engine but now would be the time to ask about that too.
Should I start a new thread on body work questions or just keep going here?
Thanks for the help and coaching!
T
tdskip
Here is the worst of it. I am handy with a MIG so some panel replacement doesn't scare me, maybe it should!
IF the frame is OK can I just cut back to good metal and let these panels in?
Gaps look pretty good good to me - but what do I know;
"IF the frame is OK can I just cut back to good metal and let these panels in?"
Yep. The only problem I can see is at the rear, near the rear spring shackles (the brackets that go up and support the rear shroud at the bottom of the boot opening). That rust could be pretty deep and those brackets are (somewhat) structural. Clean that area up real good and decide if there's enough good metal, or if you need to patch some in. The rear shroud is aluminum, and attached with rivets to the boot pan. It appears somebody went after the rivets with a chisel, but I think you can straighten it out. Side note, if you're looking for originality: the bottom lip, where the shroud is riveted to the boot pan, should be painted flat black with a brush; sometimes, that's not done on even 'concours grade' cars.
Gaps on the bonnet and boot lid look excellent, which sometimes isn't the case (those gaps on both my BJ8 and BN2 aren't nearly as good). The real test is the door gaps; sides and bottom (need photos :wink-new:smile:. When you fit the outer rockers be sure you have wings (fenders) and doors fitted before welding them up. Most of the original welds were spot- (rockers) or lap-welds; rosette welds are a good approximation for the spot welds. One of these will make the rosette welding a lot easier (and fun!):
https://tinyurl.com/yax9s6c6
The bottom of the sides of these cars should have a very slight, graceful, upward curve. Some repop rockers--well, any that aren't made by Kilmartin--have a straight bottom edge that looks just slightly 'off.' The rear wheel well opening has a wire bead, which the wing metal is wrapped around (again, AFAIK, only Kilmartin sells panels with that bead). A mistake that's often made with the dogleg repairs is to have the rear of the dogleg sticking out instead of following the curve. These look like 'spurs,' and you see that on some otherwise well-restored cars.
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
J 3000 [BT7] with 100-6 Grill Austin Healey 2
T Trade 3000 Speedometer for 100/4 Speedometer TRADE Austin Healey Classifieds 0
BoyRacer 100/6, 3000 Disc wheels Austin Healey 4
C 100/6 & 3000 door handle - a puzzle Austin Healey 5
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
D 100-6 and 3000 Child Seat Austin Healey 5
O For Sale AKD1179H 100/6 & 3000 factory manual Austin Healey Classifieds 0
BoyRacer Sloppy 100-6, 3000 door hinges Austin Healey 4
AN6-TX New Book: Factory Original Austin-Healey 100-6 & 3000 Austin Healey 8
J Drum brake instructions for 100/6 or 3000 Austin Healey 4
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
D 100-6 and 3000 MK-I Feeler Gauge Austin Healey 1
M 100-6/ 3000 tri carb set up Austin Healey 13
mrdibbles Austin Healey 100-6 & 3000 Disc Wheels - Ebay Austin Healey 2
pbraun I thought it was a 100-6, but it's a BT7 3000 Mk I Austin Healey 5
ronzet Spin-On Oil adaptor for AH 100-6 and 3000 Austin Healey 9
Bruce Bowker Book -Austin-Healey 100 & 3000 Series Austin Healey 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 6
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 9
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
