100-4 shroud
dh100m
Member
hi
I am trying to fit my front shroud having difficulty with brackets from front of chassi that bolt to bottom of shroud cannot fine any suitable pix I need to define the correct height of shroud where it
bolts to these bracket from top of chassi rail if anyone has pix greatly appreciated
thanks in advance tony
Tony--
There is a 3" wide Z-shaped bracket that attaches to the frame rail and a smaller L-shaped bracket that attaches the shroud to it. The visible dimensions of the front vertical face of the Z-shaped bracket below the lower edge of the shroud are 1/4" on the inboard edge and 1-3/4" on the outboard edge. It seems to me that these dimensions defines the "height of the shroud" that you ask about. Of course they might vary from car to car depending upon shroud dimensions, etc. Let me know if you need more info.
I have tried several times to attach a photo of the points of attachment and the upload has failed. Perhaps there is a problem with the BCF--perhaps one on my end. In any case if you send me your email either in a pm or reply I will send a pic of the bracket to you off-forum.
