I've got well over one hundred (>100) engine builds under my belt, the largest percentages being MGB, Big Healey & Spridget, and I have never-ever purchased a rod bolt. I've never had one let go either.Keoke said:Specifically, looking for advice on rod bolts. Different advisors, different advice.
<span style="font-weight: bold">Option 1: Reuse existing rod bolts.Never in your sweet life. </span>Buy new or use uprated hardware.--Fwiw--Keoke
Hey buster, that'd be my dad yer talkin' about! :laugh:Keoke said:the last guy that tightened it Ether didn't own a torque wrench or did not know how to use one.--Keoke--- :laugh:
I concur.Superwrench said:I'd worry about the rods more than the bolts. I just magged mine and one is cracked. I will reuse the bolts after I mag them also. I will use Denis Welch or ARP nuts. Bolts stay tight buy stretch. Use a stretch gage and watch for .004 to .006 bolt stretch and they will run forever. Put the torque wrench away, you have no idea if you have any stretch with one. You are only reading friction between the nut and the rod.
