Patrick--Hi Michael,
I still have the same tank sender. I just soldered a flexible metal wire strand to the sender to make a good solid sending unit connection on the advice of a good Healey friend. I’ll see if I can find the photo to post.
Patrick
I would appreciate seeing that for sure!
Michael DSalter posted a fix a few months back consisting of, as I recall, wrapping some light wire around the base of the sending arm to serve as a damper.
I am going to contact him and ask him to send me his message and will post it here.
This aftrnoon I filled up the tank after last weekend's ride and my mpg reverted from 15 according to the original speedo, which I knew had to be erroneous, to 22 which is about where it has been in past years. Based on this dramatic difference in performance the new speedo should pay for itself in no time!
