wkilleffer
Hello everyone,
My car is a 1974 MGB that's pretty much stock except for the 18GK engine. It's currently equipped with ROSstyle wheels that are probably original. However, they're rather rusty, especially on the inside, and that's causing some slow leak issues. It's time for a new set of tires, so I was looking at taking the steel wheels off the road for awhile until I can get them blasted and painted, but I'm not ready to stop driving the car since I just got it back from having its windshield replaced. So, I thought a set of alloy wheels might work well with it. No one seems to have any minilites for sale, and I can't spend the money to get them new, so I was looking at other options.
Someone has a set of Datsun "Iron Cross" wheels off a 280ZX from the early 80s on the local marketplace. They're 14" wheels with the 4x114.3 bolt pattern that matches up to an MGB's stock bolt pattern. The seller said they would measure width and offset after work today, but most of what I've found so far indicates they're 6" wide with a +10mm offset and 102mm backspace, and center bore between 71-73mm.
I've tried to attach a picture. They need to be cleaned and have the old tires removed.
Has anyone used a wheel like this on their CB MGB? I kind of like the sort of retro, shabby chic, old school look they give, like something you might see on an MGB that came out of California.
It's frustrating that wheels seem so thin on the ground right now. A very few years ago, several people not too far from here had used minilites for sale, but I couldn't do anything about it then. Now that I'm able, none are to be found. I just can't spend the money to buy new ones.
Thank you,
-Bill
Thank you,
-Bill
