        Frank Canale
	I wish I could say I came up with the idea but the professional custom car guys have been doing it long before me but I am pretty picky about my work and I like this method to those that use sheetmetal screws. Don't get me wrong there is nothing wrong with that method as well. I will have one spot that I will need to use a screw to pull the joint together to weld it because I can not get a clamp there to pull it together. I have learned that you have to be flexible in how you do things on these cars. Some things are easy and straight forward and others you have to think outside the box to solve a problem. Frank
Hi Guest!
