American version of the great british sportcar is coming. U hate it? or like it?
TypeRboy
The interior looks really plastic.. GM always has trouble with their dashes and interiors looking " cold and antiseptic..
Don Lattimer
Of course I'm sure you're all aware that "The Great British Sportscar" is Marcos. Still making 'em too.
Don Lattimer
1971 Marcos V6
tony barnhill
Great Pumpkin - R.I.P
Marcos - an interesting sidebar in the British automotive cottage industry...though I must admit that I'd not turn down a reasonably priced Marcos!
JBsZ06
SOLSTICE ADDS NEW DIMENSION TO PONTIAC’S PERFORMANCE RENAISSANCE
DETROIT - Bringing the popular concept car to life, GM announced production of the Pontiac Solstice roadster as a 2006 model. The vehicle is expected in dealer showrooms in fall 2005.
First shown as a concept at the 2002 North American International Auto Show (NAIAS) in Detroit, the Solstice immediately gained a huge following, both inside and outside of General Motors. Designed from the ground up in less than four months, the 2002 Solstice concept car promised thrilling, open-air driving freedom in the spirit of the great roadsters of the past.
Built on GM’s new Kappa architecture, the production model remains true to the original Solstice concept, including rear-wheel drive, two-passenger seating and a reverse hinged clamshell hood that opens to reveal a sophisticated double overhead cam variable-valve four-cylinder engine.
“True to the thinking behind the original concept, the production Solstice is all about being a ‘back-to-basics’ roadster with gorgeous lines and fun-to-drive characteristics,” said Bob Lutz, GM vice chairman of product development and chairman of GM North America. “The key enabler of Solstice is the new Kappa rear-wheel-drive architecture and component set, which allows us to rapidly and efficiently develop an appealing family of compact and affordable sports cars.”
Emotional design, rigid backbone
Strong response to the 2002 Solstice concept vehicle helped put the sports car on the fast track to production. But while the concept was designed with production-style elements, there was no compact rear-wheel-drive platform at GM on which to build it. Creating a production version of the concept vehicle required marrying the Solstice’s curvaceous design to an entirely new performance body-chassis architecture.
The robust Kappa architecture features state-of-the-art, full-length hydroformed frame rails and a stamped steel structural tunnel to provide a solid structure to enhance vehicle handling.
To ensure an affordable, world-class driving experience, Solstice was created with a clever blend of all-new technology and proven GM components.
Solstice’s power is created by a new 2.4-liter variable-valve version of the Ecotec DOHC four-cylinder engine, producing about 170 horsepower. Its twin-cam, multi-valve design provides stirring, high-revving performance, while the engine’s lightweight, all-aluminum construction helps optimize the vehicle’s front-to-rear balance. At the start of production, Solstice will be offered with a close-ratio Aisin five-speed manual transmission.
“With the concept vehicle, people immediately felt the emotional appeal of Solstice’s design and back-to-basics philosophy - it’s about performance, but in a fun, agile, affordable roadster,” said Lynn Myers, Pontiac-GMC general manager. “All the stops were pulled out to make sure the production model delivers an exhilarating driving experience to capitalize on the ‘promise’ of the Solstice’s design.”
Faithfulness to the concept can be seen in Solstice’s proportions, which are comparable in terms of overhangs, wheelbase and track width. Independent front and rear suspensions that feature independent SLA designs with forged aluminum upper and lower control arms contribute to responsive handling. Monotube shock absorbers and coil springs contribute to uncompromised handling response and sporty driving characteristics while the wheels-at-the-corners wide stance enhances handling. Eighteen-inch wheels and tires are standard, as are four-wheel disc brakes.
The interior is oriented around the driver, with a clean design and intuitive controls. “The interior of the Solstice is surprisingly spacious, especially for a smaller car,” said Lori Queen, vehicle line executive for GM’s small cars. “We wanted to create a comfortable environment suitable for longer drives without sacrificing the ‘personal’ feeling of a driver’s car.”
Clean lines, clever details
Designers worked carefully to transfer the clean lines and taut proportions of the concept vehicle to the production model.
“Put them side by side and it’s very difficult to tell the production model from the concept,” said Franz Von Holzhausen, design manager. “The front and rear fascias are slightly longer on the production model, but overall the car remains faithful to the concept - it’s a minimalist approach that emphasizes proportion.”
The Solstice’s proportions are accented with five-spoke wheels and a low, wide stance. A dual-port grille and expressive lighting at all corners instantly identifies the car as a Pontiac. Unexpected details include a body-color extension into the passenger compartment that gives the Solstice an integrated appearance when the top is down. In fact, the top folds flat into the rear clamshell opening, providing a smooth seamless appearance.
“There is no visible stack from the folded top to disturb the shape,” said Von Holzhausen. “In fact, there are no extraneous lines whatsoever; it has a tight, purposeful look, as if it were shrink-wrapped around the driver.”
“We insisted on a lower ride height to ensure the car’s sporty appearance,” said Von Holzhausen. “That makes it the lowest, most ground-hugging car at GM. We were adamant that the Solstice look absolutely right from all angles.”
Creative leveraging of GM resources, as well as clever solutions to other needs, helped complete the Solstice’s design efficiently and economically. For example, the rear corner lamps are from the GMC Envoy, while door handles, fog lamps, seats, engine and transmission are shared with other GM vehicles.
However, some parts are all Solstice. The taillamps, for instance, were designed with special reflectors to eliminate the need for a separate side marker light. This not only contributes to the car’s sleek design, but also eliminates the cost of a separate marker lens and bulb.
Interior design is equally purposeful and clever, with details like pedals placed for easy heel-and-toe driving and a cockpit-style instrument panel that sweeps around the driver. Designers also worked with chassis engineers to optimize the placement of the shifter. Manual shifter throws between gear changes were studied and shortened.
“When you sit down in the car, your hand naturally falls onto the shifter,” said Vicki Vlachakis, interior designer. “It’s a very intuitive, comfortable environment, and the feel of the shifter between gears is very short and precise. Designers and chassis engineers worked together to tune the best placement.”
A turning point
The production Solstice announcement further enhances a re-energized Pontiac lineup that already includes the all-new GTO and G6, Grand Prix, Vibe and a V-8-powered Bonneville GXP.
“Solstice is a vehicle that captures the passion and pleasure of open-air driving,” said Myers. “Everyone at GM recognized that adding it to Pontiac’s portfolio would make another strong statement about Pontiac’s renaissance.”
Its fast-track approval and development process come on the heels of a similar rapid decision process that helped launch the 2004 GTO in 18 months.
“The GTO and Solstice complement each other by offering ‘book-end’ approaches to Pontiac’s performance offerings,” said Myers. “Like its V-8 powered stable mate, Solstice adds another dimension to a growing lineup of clean, uncompromising performance vehicles.”
JBsZ06
Here's a car GM thinks can compete with the new mini S..
Are they on drugs or is this cool?
Whats your opinion?
That nomad looks like a '53 Vette from the nose.
JBsZ06
Here's the details from insidegm news
Super 7
What does "SLA" mean. Is that Single Lower Arm?
That would be Chapman struts in back, Mcpherson struts in front?
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by JBsZ06:
<hr></blockquote>
78Z
I think its success will depend on pricing. I like the Pontiac. The Saturn is a bit ugly and rip off of Audi and Chrysler show cars. But it looks to be built as a proper sports car - nice rwd drivetrain and not a Mac strut in sight.
A
aerog
America's version of the "great British sportscar"?
Please, spare me.
About the only thing GM has done in the tradition of the "great British sportscar" is spell "MG" backwards.
[ 01-05-2004: Message edited by: aerog ]</p>
tony barnhill
AMEN, BROTHER!
Mickey Richaud
Remember the "hidden" voice of satan in records when you played them backwards?
So, is GM satan?
tony barnhill
Mickey, in your profession, you're better able to answer that question than the rest of us...never thought of GM as the big Satan though....to me it was always BL!
ThomP
GM has (IMHO) been a stinky, stagnent, sloth for 40+ years. As much as I hate to admit it, Harley Earle may have been the last innovator to work at GM. I hate to give anyone that is reputed to be such an abuser that credit, but it was certainly that long ago.
170hp out of 2.4l and they call it a sports car? The thing had better weigh 1700lbs. Otherwise stick with the phrase "petty two seater"
As a styling efort; I like the exterior very much and at the same time, agree that the interior looks like typical GM boredom. They have to start somewhere, maybe this will improve and GM will, once again, lead the industry after 40+ years of total stupidity. I somehow doubt that last statement, because they have never produced a car, in my lifetime, that I had any respect for either because it was a huge bulbus buldgemobile or because someone else offerd a better value for a similar car (ala the Japaneese invasion of the 70s).
I genuinely like small cars, I don't see a need for everyone to be driving an SUV. I have felt this way since I was 16 so I have always been skewed toward "world" cars. I have also said "If any of the American 4 (that's how long I've been saynig it) would offer a car like an LBC I would try it." Maybe 2005 is the year.
I don't think "Roger" would have spoken with me either ;>}
A
aerog
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by ThomP:
<hr></blockquote>
No offense but I don't think horsepower is a definition of sportscar...If 170hp is a litmus test then we're likely to have a whole lot of "LBC" owners exiting the sportscar world and entering the "petty two seater" world.
Dave Russell
Yoda - R.I.P
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by aerog:
No offense but I don't think horsepower is a definition of sportscar...If 170hp is a litmus test then we're likely to have a whole lot of "LBC" owners exiting the sportscar world and entering the "petty two seater" world.<hr></blockquote>
To put things in perspective the Pontiac at 2860 pounds has about the same power to weight ratio as a BJ8.
ThomP
The BJ8 is known as the Hairy Beast for a reason. It was heavy, difficult to handle and ,face it, only marginally competitive. We are also comparing a 1950s design to a 2005 design to put things into perspective. Surley, if a real Healey were designed today, one Donald Healey would put his name on, it would be better than its predicessor!
The Ginetta is more a modern "Sports Car" at 220hp per ton than the GM Solstice thingie at 119hp per ton. The Ginetta "only" has 146hp total. So, you see, Aerog, I agree with you; What makes a sports car, a Sports Car is Performance.
A
aerog
The Ginetta is more a modern "Sports Car" at 220hp per ton than the GM Solstice thingie at 119hp per ton. The Ginetta "only" has 146hp total. So, you see, Aerog, I agree with you; What makes a sports car, a Sports Car is Performance.<hr></blockquote>
Wellll maybe, but give us those same numbers on a mid-70s MGB or Spitfire
R Rebuliding 1974 2.5L, N. American version. Triumph 27
Editor_Reid General MG GT-49, national annual meeting of the North American MGA Register MG 0
K TR2/3/3A American Racing Slot Wheels Triumph 0
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
Gliderman8 Rambler American Spotted 2
aeronca65t Old American vehicles seen in St. Pat's parade Other Cars 0
W North American Source for Hardura Spridgets 5
NutmegCT Rambler American [?] Other Cars 5
HealeyRick Imported Carr- American Gas Triumph 5
Randy Forbes O.T. Detroit's North American Int. Auto Show... Austin Healey 10
angelfj1 American Racing Silverstone Wheels for Sale Triumph 11
angelfj1 New American Racing Silverstone Wheels Triumph 12
Steve MGB American MGB Association annual meet 2010 MG 14
bgbassplyr American Pickers Other Cars 6
M are the British cars the same as American Spridgets 7
3798j American V8 Engine Quiz Other Cars 21
M British to American dictionary Spridgets 23
StagByTriumph Triumph Trans American Charity Drive - TWEETS! Triumph 0
Y American Racing Lemans wheels Triumph 10
M MGC American MGC Register CBA Mk. XXIX MG 1
RickB American Racing 4 on 4 Wheels - $150 Portland OR Spridgets 6
rick_ingram British-American Deviant Automotive Sportscar Soc. MG 3
MadRiver American Racing Silverstones Triumph 31
Steve P. Brit vs. American hydraulics Spridgets 10
angelfj1 13-inch American Racing Wheels on eBay Racing 0
kyreb1862 American Racing Libre Wheels MG 7
R American Silverstones [vintage type] Triumph 10
R Which American Car is Trustworthy? Other Cars 0
StagByTriumph Triumph Trans AmeriCan 2009 Charity Drive -status Triumph 5
V Triumph Trans-American Charity Drive 2009 Triumph 8
StagByTriumph Triumph Trans AmeriCan 2009 Charity Drive, Status Triumph 1
B An American harness for a british car Spridgets 3
MadRiver American Silverstone Wheel Dummy Nut Question??? Triumph 13
weewillie american muscle Other Cars 6
S Little American Car??? Spridgets 2
Sherlock Wedge TR7 with American V8 Triumph 3
E Smolenski sells TVR to American company TVR 14
S Big American Iron? Other British Cars 7
angelfj1 Tubeless American Racing Silverstones??? Triumph 4
Tinkerman British fuses vs American fuses Triumph 17
G British Fuses vs American Fuses...big difference Triumph 17
tony barnhill Grand Prix American Rolex Sports Car Series Racing 3
M MGC American MGC Register Up-date MG 1
PAUL161 MGB North American MGB registration MG 12
S austin american Other British Cars 5
Sherlock Vintage American cars - the real vintage ones Other Cars 24
Henri American Austin Other Cars 8
Sherlock Jaguar Owners North American Tour - anyone going on this? Jaguar 1
W Converting from American to British Bumpers? Jaguar 1
J Brake line- british same as American? Austin Healey 7
