General Tech New Camshaft Has Rust
KVH
I just opened my new camshaft from the big source. It had surface rust on four areas. I cleaned it up with acetone. Some tarnishing appears, but I can't feel any depth to the rust effect. Should I nevertheless send it back? It all appears cosmetic but I don't want to overlook what others might see as highly material. It seems to my that a few hits on the lifters and it's all the same anyway--but what thoughts do others have.
Rut
Don't accept sub standard products from anyone, send it back.
Rut
KVH
KVH
What was wrong with the old camshaft......do you intend installing a new cam into the old cam bearings ?
I wasn't planning on pulling the engine. My old cam had two bad lobes, and I'm fairly certain it's because I failed to conduct proper break-in when I rebuilt the engine "in-situ" 14 years ago. I was getting loud tappet banging for months and decided the check the car and lifters. Sure enough, two of each were bad. Eyeballing the cam bearings isn't showing anything, and most people here seem to believe that cam bearings are fairly resilient to wear and even abuse. Pulling the engine is another bunch of hours and expense I'm not sure I'm ready to invest, endure and incur right now.
Do you feel strongly I should?
KVH
KVH
I'll take it into my crank shop and see what they say. I'll report back.
CJD
Cams get surface rust, that you never see, while sitting in an engine that doesn't run for a month or two. In general it is not great, but seems to cause little harm. That said, I would expect a new cam to be plenty greased up and free from rust. If you had a break in issue with the old cam, starting with a rusted one will not improve the odds of a good break in on this one.
That probably tells you nothing. If it were mine, I would use it if I were in a hurry to get rolling...but use the GM cam break in lube on all the lobes and lifters. If I were in no hurry, then I'd return it for a clean cam.
sp53
I hate returning stuff, but I do all the time. Why don’t these guys realize we are fussy-- these cars belong to us-- not someone else --not that we would do crappie work, but it is a hobby for most of us not a business and we care probably too much. I just spent 25.00 for shipping and handling back and forth on parts I will not get!!!!!
Frustrated
malbaby
IMHO...if pulling the engine is not an option, then all you can do is install a new cam [or have your old one rebuilt] and hope for a good outcome.
If you were to pull the engine, I would have the old bearings remetalled and installed, then line bored to suit the camshaft, all by a dedicated engineering workshop
Sarastro TR4/4A Camshaft oddity has me concerned Triumph 6
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
D Stock Camshaft TVR 0
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
nichola TR6 GP3 Camshaft won't turn Triumph 8
BN6 Healey 3000 Camshaft Identification Austin Healey 4
A Camshaft Austin Healey 0
R Woodruff key for DWR camshaft? Austin Healey 2
KVH General Tech Camshaft Breakin Triumph 2
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
rjhco For Sale Camshaft lifters - tappets - followers Triumph Classifieds 0
E TR6 General Inquiries.....Camshaft and valve clearances Triumph 3
Rut 1275 oil pump, camshaft adapter Spridgets 2
KVH General TR Torque for the Camshaft Bolts Triumph 3
KVH TR4/4A Is this Camshaft OK? Triumph 7
T TR2/3/3A Camshaft Recommendation Triumph 13
B BJ8 Camshaft Question Austin Healey 3
B Camshaft choices Austin Healey 11
T TR2/3/3A Degree Reground Camshaft Triumph 2
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
T TR2/3/3A Camshaft Front Bearing Bolts Triumph 3
T TR2/3/3A Camshaft Questoin Triumph 2
T MGB MGB Camshaft MG 1
H TR6 TR6 camshaft options Triumph 9
DornTRoriginal Is the sprocket on the camshaft supose to fit so bloody tight? Triumph 4
L 1275 Compression, Camshaft, et al Spridgets 16
S TR4/4A TR4A camshaft recomendation Triumph 6
B Camshaft specification, what have I got? Austin Healey 15
M BJ7 29F Eng Camshaft Info Austin Healey 1
dklawson Camshaft - Degreeing w/o Pulley Marks Triumph 17
N Camshaft query???? Spridgets 9
M Tri Carb Camshaft Austin Healey 4
B Camshaft bearings MG 6
nissanite Lifter & Camshaft relationship Triumph 5
PATR8 Camshaft bearings replacement Triumph 5
T 100/4 Camshaft Austin Healey 1
N Check camshaft type Austin Healey 28
I camshaft and camshaft bearing information please Triumph 1
D Camshaft Austin Healey 19
PatGalvin TR2/3/3A Camshaft/Crank alignment on TR3 Triumph 5
Tr4dude TR4/4A any idea on this Tr4 camshaft? Triumph 3
PatGalvin New Camshaft - Any BCF Members Interested? Triumph 2
doughairfield Timing chain sprocket to camshaft Triumph 9
A Spitfire Spitfire 1300 camshaft dimensions Triumph 7
Stinger TR4/4A Need TR4A Camshaft Bearing Setscrew Help Triumph 5
P Camshaft Questions Triumph 10
Sarastro Camshaft installation/end float problem Spridgets 16
