MGB Wont stay runing
Carlbanan56
Carlbanan56
Member
Hi,
I have just got my car that has been sitting for 25 years to start! That's a very big achievement for me. Unfourtenetly the car will not stay running. When first starting the car it will start and run for 5 to 10 seconds and then die. When I then try to start again, the car will not start. If I let the car sit for a few minutes and try to start it, it will run again but still for only 5 to 10 seconds. I have taken a look at my brand new sparkplugs and there is a little soot on them. I am there for guessing that the fuel-air mixer is rich. But can the mixture be so rich the car won't start? I have completely renovated my carbs with a kit with new parts. My fuel tank is pretty rusty so I have removed the pump and temporarily placed it in the engine bay with a small gas container hooked up, so I am pretty sure the carbs are geting fuel from the pump. Should I just turn the adjuster screw to make the mixture leaner or do you guys might think there is something else?
Young and inexperienced :smile:
Thank you beforehand
NutmegCT
Hi Carl - some questions for you:
1. Which MG model and year?
2. Which carburetors?
3. How did the engine start and run *before* you rebuilt the carburetors?
4. If you disconnect spark plug wire, and try to start the car, are all the plugs wet with gasoline?
5. Is each carburetor fuel bowl filling to the proper height?
6. Are you using choke to start?
Every one of us here started as "young and inexperienced".
Thanks.
Tom M.
Carlbanan56
Carlbanan56
Member
1. It's a 1975 mgb
2. HIF4
3. I renovated my cabs before I ever got the car to run, in hindsight this was maybe the smartest move.
4. I will try this tomorrow and come back with an answer.
5. I am not sure how I can check this now that the carbs are installed but during the assembly, I set the float bowl level.
6. I have tried using both with and without, and don't notice any difference. But have mostly tried with the choke.
JPSmit
5-10 seconds is pretty much exactly the amount of gas in the float chamber. Simple things first. does the glass gas container have a vent hole in it to keep the fuel flowing?
after that, it is likely either the float or the float needle? (Don't assume the needle is good because it is new - the viton tipped ones can be defective)
another possibility is that the pivot pin for the float lever isn't dropping and opening the float needle as the fuel goes into the carb.
I do feel like it is your area of focus though - good luck!
YakkoWarner
I'd start with the simplest old-school solution (which also works right nicely on Seagull outboard motors that have a carb with external float chamber) - give the float chambers a couple nice thwacks with the plastic handle of a screwdriver. Float could be stuck UP (closed) and over time enough seems thru to get it to run again for a couple seconds. Another way to test is bottle-feed a small amount of fuel (not carb cleaner or starting spray or any kind of solvent - I like to use 40:1 chainsaw gas because it has a little oil in it) into the carbs and see if it'll stay running on that. This is tricky on the side-draft SU's but can be done with one of those squeeze bottles.
saabmp3 hood wont stay latched Spridgets 1
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
M Spridget wont start Spridgets 50
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
J TR6 Wont Start Triumph 10
S TR2/3/3A Frustration has started but car wont. Triumph 4
K TR6 Engine Dies and starter wont turn over Triumph 4
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
Tinkerman TR2/3/3A 60 TR3A wont start??????????????? Triumph 7
glemon TR5/TR250 Turn Signal Wont Blink Triumph 1
C TR5/TR250 Car wont accelerate Triumph 6
T TR2/3/3A new rear brakesshoes wont fit Triumph 10
S MGA Cleaned engine compartment on MGA - wont start now MG 9
T seat Belt Buzzer Wont shut off Triumph 5
R Wont Go Into Reverse MG 6
tri_carb_healey float bowls overflowing/ wont start Austin Healey 5
Newkie Car wont start sometimes MG 8
M 78 Midget Seat Wont Move Spridgets 20
M Seat head rests;...It wont go down? Spridgets 7
rlandrum TR2/3/3A TR3A Engine Wont Turn Triumph 52
Newkie Headlights wont turn off! Hellpp MG 25
Newkie Trunk lid wont close... MG 13
RickB Steering wheel-removed but new wont fit +New Pics! Spridgets 26
G spin on adaptor wont break free Triumph 10
jjbunn Electrical problem: car wont start Triumph 23
J Jaguar wont start Jaguar 5
hondo402000 Starter problem and motor wont shut down Triumph 22
Stewart electrons wont flow MG 7
RTMG T-Series My baby has lost juice - MG TD wont start MG 13
zimmy runs fine but wont start Spridgets 15
B BJ8 Choke cable - wont move Austin Healey 19
Stewart Idle problem IE wont MG 7
E Supercharger wont start MG 16
Woodie key barrel wont go back Spridgets 29
I 1979 wont go into reverse MG 10
D 1985 xj6 wont start, need help ASAP,no car :[ Jaguar 2
R wont run Austin Healey 6
Scott_Hower MGB MGB - Left turn signal wont flash, brake light dim MG 16
P wont start Jaguar 2
N She wont start! Austin Healey 10
C Car wont start when warm Jaguar 4
7 My car wont start?? MG 9
L Axel wont seat against Hub Austin Healey 5
coldplugs T-Series Help! Carb, intake, etc.. Car wont start MG 6
longbridgehealey Bonnet stay Spridgets 3
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
B Why can't I stay logged in to this site without entering user and password info? FORUM Navigation Questions 8
Lin A little "Stay-at-Home" Healey Nostalgia Austin Healey 10
C Heater knobs won’t stay on... Austin Healey 4
60TR3A Driver's Door Won't Stay Open Austin Healey 1
