Wiring is out! [mostly]
drooartz
The harness is now out of the Tunebug and on the floor. All that's left is the wire to the fuel tank, and the headlight pigtails. I need to find a siphon to drain the full fuel tank, and I'm going to wait to pull the headlight wires until I see what the new ones look like. I've got a few new photos of the progress up here:
https://www.drooartz.com/index.php?page=27
We're coming right along. Should get tools and the new harness in by early next week, and I've got a long Moss order list together of all sorts of bits I need right now (coming your way momentarily, Tony).
-Drew
That harness looks so simplistic compared to the one in my '70 midget!
tony barnhill
Great Pumpkin - R.I.P
Drew - I got it, filled in the column you left for me &, hopefully, it went back to you...never done that before.
JPSmit
Most of the gas had gelled in my tank. I found it just as easy to drop the tank and then pour out the gas. It's not that big and I think I put my hydraulic jack under it. My 2 cents
jlaird
Oh, that's correct. Use to get the gas for my mower from there. In addition no baffels in the filler tube so you can sifon (sp) easly.
drooartz
drooartz
It does have a drain plug, but I don't think I've got anything big enough to hold all the gas. I stupidly topped off the tank right before I decided to work on the car. I figure a siphon will be a little easier to manage than the drain.
I have a target date now for registration--April 7th. I've got that Thursday and Friday off work, so I can get down to the DMV and get the registration stuff taken care of. Hopefully the weather will be good so I can spend the weekend driving around town!
-Drew
ps: Tony, I got the email but the file was not attached.
jlaird
As I remember I had a peice of 3/8 plastic tube, the kind you get at the hardware for cheep.
Bugeye58
Drew, it only holds 7 gallons. Drain half, screw in the plug, and come back for the rest. No nasty aftertaste this way!
Jeff
Platinum
I kinda thought the same thing, Jeff...How much could possibly be in a "full" bugeye gastank?!?! Two five gallon "portable" cans and it's DONE. I was guessin' t'wixt 8 and 10, but thought it closer to 8, trying to remember the physical size.
drooartz
drooartz
I wound up picking up a cheap siphon from the local auto parts guys. It has a little bulb to squeeze to make the suction. I worked okay, and I didn't have to drink any gasoline.
Of course, now I'm considering not dropping the tank for a while. Trying to stay focused on getting enough stuff working to get the car registered, then I will worry about other stuff. Next time I'll try the drain plug.
-Drew
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
TomMull Dash wiring Plus 2 S Lotus 16
MadRiver BT7 Wiring Diagram Austin Healey 4
R TR2/3/3A Replace wiring harness in steering column Triumph 61
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Sopwith_Camel MGB wiring new Tacho MG 0
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
