Spitfire Which carburetor is the best?
FlyingCat
I'm ready to purchase a carburetor for my 1980 Spitfire (Federal). Right now I'm pretty well sold on the Weber DGEV, unless somebody has a better idea. (The original ZS carburetor is long gone.) I live in the Willamette Valley, so it never really gets that cold in the winter (it's rare to get below freezing), and it doesn't get that terribly hot in the summer -- 90 is about tops. I do, though, have mountains all around me. I'm not sure if any of that makes a difference in what carburetor I get. On the Weber, I know that I can choose either water, manuel, or electric choke. Which is best? Thanks!
dklawson
There are lots of options and lots of opinions.
Start by asking if you are going to have to pass emissions testing when you put this car back on the road. Some locations require original equipment intake and exhaust (emissions) components.
If you are allowed to change the carb, some of the common choices are a replacement Stromberg, a single SU HS4 (with MGB needle and slightly modified mounting holes), a Weber, or the European dual SU HS4 carb package. I cannot comment on the Weber but I know it is a common choice. Once properly jetted they are supposed to be great. We ran the single HS4 on our 1500 all the time we had it. It worked like a champ and gave no trouble over 6 years. The dual SU HS4 package is supposed to be a nice setup but I have no experience with it either. Apart from those interested in originality you probably won't get many endorsements for the single Stromberg.
Again, start by looking at your local regulations.
TR3driver
Great Pumpkin - R.I.P
I would be tempted to look for a dual SU setup, rather than the Weber. But that's just me. I don't know much about the DGEV, and I'm a lot more familiar with SUs.
My preference would be manual choke, since it lets you adapt directly to conditions. If the engine needs just a bit more choke under some circumstance; pull the knob out a bit. Getting an automatic choke adjusted just right can be tricky sometimes.
For example, on a cold morning, my TR3 (with dual SUs) will idle smoothly with less choke (just the fast idle cam really) after a mile or two (from my house to the freeway ramp), but needs a bit more fuel to make full power going up the ramp to the freeway. No way an auto choke can cover that.
FlyingCat
FlyingCat
Emissions requirements is definitely something to consider. In Oregon, we have the DEQ -- Department of Environmental Quality. They apparently don't care if your car will stop, only if it doesn't pollute. Thanks!
poolboy
If that's so and the car has to pass a 'smog inspection' they may not be happy with anything other than what the car was born with.
dklawson
I think some phone calls are in order.
Oregon Overview Link:
https://www.oregon.gov/deq/Vehicle-Inspection/Pages/Portland-Required-to-Test.aspx
From the above...
Vehicles required to (emissions) test
All 1975 and newer cars, trucks, vans, motor homes and buses powered by gasoline, alternative fuels (such as propane) or hybrids registered within the Portland testing boundaries.
and (test methods)...
https://www.oregon.gov/deq/Vehicle-Inspection/Pages/Test-Methods.aspx
Oregon DEQ Vehicle Test Methods
Tailpipe emissions test
(1995 and older model years)
At a Clean Air Station, a DEQ inspector places a probe into the vehicle’s tailpipe to ensure vehicle emissions are not exceeding standards
I did not see mention of "original equipment" but it is probably required... and worth a phone call or two before you buy any new carb(s).
FlyingCat
FlyingCat
Just a quick update. I spoke with the folks from DEQ, and all they are interested in is that the car has a catalytic converter (because it originally did) and that the tailpipe emissions are within range. They not only don't care if you have the original equipment under the bonnet, they aren't lifting the bonnet to see. The fellow I spoke with said that as long as the carburator is set correctly and the catalytic converter is new, then I shouldn't have any problems. Let's hope he is right, because that emisssions stuff is really expensive... if you can find it at all.
STeve 1958
I had a GT6+ which a threw away the emissions control junk. Big mistake. Ended up having to buy it all again. That's California though. The TR3 doesn't even need a smog check due to age.
I've heard that the SU carburetors produce more power but the Strombergs are more reliable.
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
SMGoose Carburetor piston not falling freely Triumph 7
D Carburetor Backfire on acceleration at low speed Austin Healey 18
