Where's the VIN on a UK Mini?
Creatrixx
I probably should have just bought a used Civic. Shipping cars from England just doesn't seem to be worth it. I was told that my 1980 Austin Mini is too old to have a VIN and didn't think much of it. Now I'm being told that not only does it has to have a VIN to get through customs, but that they did have VINs in the UK in 1980.
Can someone tell me where I'm going to have to look to find the VIN? There is also a 17 digit number on my bill of lading that is where *a* VIN should go, but it doesn't seem to be valid (on the online VIN checks that I tried). What should it's number look like?
I hope I'm not buying a stolen car. I can't afford to ship it back.
~Melissa
Below is a link to the MiniMania website decoding VIN codes.
https://www.minimania.com/web/SCatagory/G...89/ArticleV.cfm
Your mini should have a VIN number, but I am not sure where the plate is attached. On my brother's (1986) mini the VIN plate is attached to the right-hand inner wing valance. Looking up VIN codes through the internet does not work, because these cars are not in the US database.
Have the seller supply you with information about the other ID numbers (engine number and body number)
Hope this helps,
Steven
Thanks, everyone! I got my car through customs now. Due to a busted hose, it is now a very adorable driveway ornament.
Jim_Gruber VIN where else to look for #'s on a BE Spridgets 6
Jim_Gruber The VIN # for a Bugeye is located where? Spridgets 6
S TR4/4A Where are the vin Numbers located on a 66 TR-4? Triumph 8
R BJ-7 VIN number. Where is it? Austin Healey 2
B MGA Where to Buy, What to Buy? Axle Nut MG 9
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
