TR2/3/3A Where does this screw go?
Momikey
Ok I found this little screw on the driver side floor. Any ideas where it goes?
mgedit
If you are going to buy one, might consider three like these. I found the allen key grub screws to be much easier to tighten. Cheers, Mike
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
M TR4/4A Where does this attach? Triumph 7
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
Tinkerman TR2/3/3A Where oh Where does the other end go? Triumph 4
Lbp TR2/3/3A Furflex Door Seal - Where does it go? Triumph 3
J MGB Name this part? Or , where does it go? MG 9
AngliaGT 4speedDatsun B210 - Where Does it End? Other Cars 4
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
CJD Where does the oil go? Triumph 9
Got_All_4 Wedge 80 TR7 PI where does this go Triumph 7
richberman Where does this panel fit? Austin Healey 2
Brooklands Where does this part go? Triumph 8
I Does anyone know where to get some of these? Spridgets 5
Tinkerman Where Does YOUR Tube Go? Triumph 12
Newkie Where does the commision no. badge go? MG 2
F Where does this wire go ? MG 1
davidk Where does it end.... Triumph 14
Bruce_B Where does hose from timing cover go? Spridgets 6
Bruce_B Datun 5 speed--where does the Speedo cable attach? Spridgets 26
R BJ-7 Steady Bracket? What is it & where does it go Austin Healey 20
mjobrien Flasher for BN1 - Where does it mount? Austin Healey 8
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
tomshobby Where does it end? Triumph 24
J Spitfire '70 Spitfire MK3 - Where does this attach? Triumph 10
vping Where does this go? MG 9
Basil Where does this go? Jaguar 11
R where does all the oil go? Triumph 2
G Where does my oil pressure line connect? Spridgets 4
E Does anyone know where this XKE ended up Jaguar 6
P Where does this go? Sunbeam (Rootes) 4
B MGA Where to Buy, What to Buy? Axle Nut MG 9
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
