Where can I obtain dash lights and switches from.
Ofcalipka
Does anyone know where I could find a full set of original dash lights, the turn, highbeam, charge, ect. as well as all the original switches, headlight, dash dimmer, hazard, ect. The prior owner decided he knew better than MG and well lets just say he is a fire hazard waiting to happen when it comes to wiring. I have a 1976 MG Midget 1500 and I wouldn't mind even paying for some used switches and lights as long as they were servicable and still looked decent.
Thanks in advance,
Adam
Jim_Gruber
Watch on E-Bay. Used dashes complete with all instrumentation pop up on there regularly. Probably won't find a donor car locally but you never know. Watch local Craig's List for a donor car. MOSS Motors and Victoria British sell all of the parts and pieces but that comes at a premium as well. I'd recommend replacing the complete wiring harness if things are as hacked up qas you describe.
Jim_Gruber
British Wiring.com for Wiring Harness.
Ofcalipka
Ofcalipka
Fortunatly for me I'm really good at wiring so I repaired, improved, or replaced anything in the harness that needed it. However the current lights and switches that I have look like they were bought at radio shack and just shoved into the dash. It is just not a clean look to an otherwise impressive car.
JPSmit
do you have pics? sadly your description describes much of the British Car Industry at that time - we might also be able to cobble things together
Ofcalipka
Ofcalipka
Ask and ye shall receive:
https://i22.photobucket.com/albums/b307/alipka/MGDash1.jpg
This photo shows what the previous owner did with the right turn signal indicator light the two red lights are the highbeam indicator and the charging light, The pull switch is the headlights now, and the green light by the radio turns on when I crank the engine over but otherwise I'm not sure what it is supposed to be, There is also a green light above the cigarette lighter that seems to serve no purpose even though it is wired into the harness with a yellow and brown wire.
https://i22.photobucket.com/albums/b307/alipka/MGDash2.jpg
This photo shows the left turn indicator, a toggle switch the previous owner used for an ignition switch which is now just filling an otherwise empty hole. The button where the heater control should be is the horn switch since the aftermarket steering wheel did not seem to be compatible to the prior owner. This too will change later but for now since I don't have a heater at all I'm in no rush to correct this one.
Honestly, the turn indicators are probably a functional improvement over the originals. The other stuff... I dunno.
The reproduction switches that are available from the suppliers are usually pretty flimsy. So if you can find some originals you should consider using them (even if they are a little tired looking).
Ofcalipka
Ofcalipka
Also I've looked on ebay and people are asking like $40 per switch and bulb. That is just too much for me still yet.
Jim_Gruber
Just keep looking for a complete dash with instruments that is the correct year. It may take a month or so but you can find. That other this is ask on multiple lists that support Spridgets. Lots of folks end up with donor cars, these things tend to follow one home.
Ofcalipka
Ofcalipka
Okay, since my wife just might kill me if I brought a parts car home. I'll keep asking in the forum here. Does anyone have any lights or switches that they could sell or donate to my cause here? I'll pay something reasonable or make a Midget available to you for your next Hawaiian holiday.
JPSmit
hang around here & ebay and it will come to you fairly soon - fortunately, nothing you are looking for affects driveability.
the light by the cig lighter is (I think) the EGR or Catalytic Converter warning light.
Not sure what the Midget parts scene is like in Hawaii, but, folk here are starting into car show/ autoumble season - can anyone keep an eye out?
JPSmit
Oh, and didn't someone just buy a ton O parts?
Ofcalipka
Ofcalipka
The Midget, Sprite, or even the MG in general scene here in Hawaii is almost nill at best. I know where a MGB GT and another Midget are that I could probably get for a fair price but they are in too good of a condition to use as parts cars.
R
RonMacPherson
Then look up Brett Pruitt in the phone book, call him and ask about the BCCH. It might be a pleasant surprise.
Also Hawaii Import Parts, just off of Ward Avenue can order a lot of parts for these cars..
Ofcalipka
Ofcalipka
I saw a web page for that group at https://britishcarclubhawaii.org/default.htm but it does not look like it has been updated in a very long while and the contact email address there seems to be no good. Are they still active at all?
jlaird
I bought two sets off of Ebay and broke the plastic out of one and cut the metal of off the other so I had one working set. The prob is getting them apart without breaking the plastic screw part.
B MGA Where to Buy, What to Buy? Axle Nut MG 9
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
M TR2/3/3A Where does this screw go? Triumph 6
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
