TR6 What to do while at the shop...
Marmoset54
Member
Hey fellas,
Saving up for the overdrive conversion of my TR6. I believe the car is entirely stock which gives me an even bigger hole to put my money in. YAY!
Assuming the car is stock, what other work would you have done at the shop while having the OD installed? I know there is discussion about new compression ratios and whatnot. The shop appears to be about an hour away and I want to make use of the time while the car is there.
Suggestions? I have my online shopping cart filled at moss motors just for when monies are avail.
So...suggestions? Thanks!
malbaby
I assume that you are contemplating the J type Triumph OD for an original transmission...... [or a Toyota/Ford 5 speed conversion].
In regards to other work besides the clutch, depends on the present condition of the engine and drive line...There are a lot of possibilities for upgrades.
M
Marmoset54
Member
No sir. A Type. Just missed the cutoff for J.
poolboy
The car shouldn't be in the shop very long if they have the parts...maybe a couple days if they procrastinate and take frequent breaks.
The engine will not need to be removed only most of the interior, seats, dash support, carpet, and tunnel and transmission....Of course examine the clutch components... have the fork pin reinforced on the clutch shaft if it's not been done by a PO.
So, maybe just have the U-joints greased and the differential mounts checked...If this hasn't been done ask to check the crankshaft endfloat at the flywheel since it will be exposed with the transmission out of the way...
All that will add another day to the project.
Platinum
Good suggestion, Ken. That's a big deal which gets overlooked a lot if a shop is not familiar with those engines. Had a couple over the years show up at the shop, owners thinking the clutch was knackered. Thrust bearings worn to th' nubs, most of 'em turned to debris in the sump...
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
KVH General Tech Carbs Flooding While Car Sits Triumph 55
F TR6 Pegged out hot while cold Triumph 7
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
kodanja TR2/3/3A Hey Its been a while Triumph 5
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
pkmh Humorous moment while detailing Healey flasher unit Austin Healey 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
S It's been a while since I posted... Spridgets 13
Steve1970 TR6 Ok if T.O. bearing is spinning while clutch is engaged?? Triumph 5
trrdster2000 GT6 Been a while on a GT6 transmission. Triumph 2
J Stress Reliever while installing new top on BJ8-smashing the Christmas lights Austin Healey 5
KVH TR4/4A Generator Light Turned on While Out on New Engine Build Drive Triumph 9
J MGB Project car done; front end clunk noise while braking MG 4
Gearhead_Garage Fuel backup while filling Austin Healey 24
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
PAUL161 T-Series Suspending work on the car for a while MG 21
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
W Bought a used center console a while back..... Spridgets 6
John Turney Get it While It's Hot Austin Healey 2
Jer and while I wait for throttle shafts to be delivered... Spridgets 8
DNK While the Wife's Away Triumph 0
Mickey Richaud Been a While... MG 6
tinman58 TR5/TR250 TR 250 "While I am there" Triumph 23
RickB While searching Craigslist for Midgets... Spridgets 9
RickB VERY OT - what I'm doing while on sick leave... Spridgets 10
mrdibbles Balancing Wire Wheels - While mounted on the car Austin Healey 18
R motor tests while still in car Spridgets 7
PSJ BN1 hub nuts - loosening while driving? Austin Healey 17
60Bugeye Bare Metal Protection/Prep While Doing Bodywork Restoration & Tools 6
M While I've got the Midget's windshield off... Spridgets 10
K Apologies! Been a while Triumph 14
scoutll Spotted while on my trip Spotted 1
JPSmit While we are on the subject of wheels for sale Spridgets 3
H TR2/3/3A TR3 -- Pull the head "while I'm in there . . ." Triumph 9
T Anything else to do now while she's like this? Spridgets 20
G Just curious while waiting on parts!! MG 30
regularman Found one problem while fixing another Spridgets 9
T Well, took a while but I got her running. Spridgets 11
RickB While cleaning some stuff, look what I found MG 6
pakiwi Replacing Pipes while the head is off Spridgets 12
