MGB-GT what is the length of mgb leaf spring,pin to pin
trfourtune
Hi all,
as stated above, what is the distance from pin to pin of a mgb leaf spring? I am asking because i want to see if i can install mgb composite leaf springs in my tr4 (yes i am from the other side of the tracks) The 135 lb rate is close to a stock tr4 spring (+7 lbs)so i was considering retro-fitting a set of these?
even if you can take a measurement with your car on the ground would be great.
thanks
Rob
Billm
I have a used pair from a '66 in the garage, the cl to cl distance is 41.75"
Bill
chris roop
A quick measurement of a spring from a 73 shows 42 1/2" as the crow flies, center to center. This is out of the car, laying on the floor, and the springs were replaced due to sag. HTH!
P MGB 1974 MGB front spring length. MG 0
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
J MGB Length of MGB oil stick for 1971 MG 1
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
D Choke Cable Length Austin Healey 0
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Healey Nut Cross Rod Correct Length Austin Healey 14
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
warwick-steve Exhaust Tailpipe Length Austin Healey 11
D Rear spring length question. Austin Healey 6
B BJ7 dip stick length Austin Healey 11
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
TomMull TR2/3/3A Parking brake cable length Triumph 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
D MGB Spring length MG 1
D TR2/3/3A Vent lid link length Triumph 8
S Funny Fan Blade Length Austin Healey 10
C Leaf spring length Austin Healey 4
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
RJS TR4/4A OD Speedo cable length? Triumph 3
stuntflyr What is the length of the bare 3000 MkII frame? Austin Healey 5
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
B Dip stick / tube length for a BJ7 Austin Healey 3
T TR2/3/3A What length fan belt for TR3A with GM 7127 alternator? Triumph 4
RAC68 Request Battery Cable Length Austin Healey 3
AHS TR2/3/3A Fan extension length for TR3? Triumph 7
nevets Front brake hose length Austin Healey 10
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
A TR4/4A TR4A Throttle - Lower linkage length Triumph 1
T MGB-GT Water Pump Nose Length MG 2
S Wheel stud length???? Triumph 10
justin_mercier Wedge TR7 / 8 alloy wheel lug nut shank size / length? Triumph 13
T Bugeye clutch MC push rod length Spridgets 6
smaceng BE Throttle cable length? Spridgets 4
I Bugeye exhaust stud length for muffler? Spridgets 2
1 MGB-GT Engine hoist/crane boom length? MG 17
I Bugeye heater air duct length? Spridgets 3
M TR2/3/3A 1956 TR3 starter length handle Triumph 2
jvandyke choke cable length Spridgets 11
chicken Spring length for horn button Austin Healey 3
chicken Windscreen wiper arm, what length Austin Healey 9
T TR2/3/3A TR3 Bolt length/decoder ring? Triumph 3
HAN8L1965 Length of Steel Wheel Tire hold town Spridgets 7
K Input shaft length? Triumph 2
M Driveshaft length Spridgets 6
A TR2/3/3A TR3 starter handle length Triumph 8
Atrus Driver front hard line length Spridgets 2
J Handbrake cable length? Austin Healey 1
