TR2/3/3A What length fan belt for TR3A with GM 7127 alternator?
TuffTR250
Can anyone tell me the correct length and width of fan belt to use on a TR3A with a GM 7127 alternator with the special wide pulley on the alternator? Also it would help if you have a part number and brand name. The original 900 cm (length) generator belt is too short so I bought a 995 cm belt from NAPA thinking it would work, but even that is too short. Before I bought the NAPA belt I looked on the Revington web site and they listed 3 different fan belts for use with alternator, the longest being 1000 cm, but that obviously is not long enough with the GM 7127 alternator. Thanks for the help!!Regards,Bob
TR3TR6
I used a Gates TR24379 and it worked prefect. Not all of the auto parts stores carry it. Bumper to Bumper does have it if you have one of there stores near you. Bob after reading your post again, this one would not work for you either. The size of this one is 3/4" x 38 1/2 " of 19mm X 980mm. It sounds to me like the diameter of the pulley on the alternator is larger than mine.
T
TuffTR250
I bought one of the NAPA 25-24379 and was able to get it to fit, although it was a struggle. It is actually 5/8 inch wide (the package says it is 3/4 inch) and although it is shorter than the first one I bought, it fits because it is narrower and thus goes down more into the grooves of the pulley. To get the 24379 belt on I had to remove the alternator from the mounting bolt and angle the alternator inward to allow the belt to go on the alternator pulley and then force the alternator back to align the long bolt with the mounting hole on the alternator. It's a bit of a struggle, but doable. Regards,Bob
gubba
I just used the original pulley off of the generator. I had the machine shop drill out the hole to fit the new alternator. Kept the same original belt. Everything worked out fine.:encouragement:
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
S Funny Fan Blade Length Austin Healey 10
AHS TR2/3/3A Fan extension length for TR3? Triumph 7
P MGB 1974 MGB front spring length. MG 0
D Choke Cable Length Austin Healey 0
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Healey Nut Cross Rod Correct Length Austin Healey 14
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
warwick-steve Exhaust Tailpipe Length Austin Healey 11
D Rear spring length question. Austin Healey 6
B BJ7 dip stick length Austin Healey 11
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
TomMull TR2/3/3A Parking brake cable length Triumph 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
D MGB Spring length MG 1
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
D TR2/3/3A Vent lid link length Triumph 8
C Leaf spring length Austin Healey 4
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
RJS TR4/4A OD Speedo cable length? Triumph 3
stuntflyr What is the length of the bare 3000 MkII frame? Austin Healey 5
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
B Dip stick / tube length for a BJ7 Austin Healey 3
J MGB Length of MGB oil stick for 1971 MG 1
RAC68 Request Battery Cable Length Austin Healey 3
nevets Front brake hose length Austin Healey 10
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
A TR4/4A TR4A Throttle - Lower linkage length Triumph 1
T MGB-GT Water Pump Nose Length MG 2
S Wheel stud length???? Triumph 10
justin_mercier Wedge TR7 / 8 alloy wheel lug nut shank size / length? Triumph 13
T Bugeye clutch MC push rod length Spridgets 6
smaceng BE Throttle cable length? Spridgets 4
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
I Bugeye exhaust stud length for muffler? Spridgets 2
1 MGB-GT Engine hoist/crane boom length? MG 17
I Bugeye heater air duct length? Spridgets 3
M TR2/3/3A 1956 TR3 starter length handle Triumph 2
jvandyke choke cable length Spridgets 11
chicken Spring length for horn button Austin Healey 3
chicken Windscreen wiper arm, what length Austin Healey 9
T TR2/3/3A TR3 Bolt length/decoder ring? Triumph 3
HAN8L1965 Length of Steel Wheel Tire hold town Spridgets 7
K Input shaft length? Triumph 2
M Driveshaft length Spridgets 6
A TR2/3/3A TR3 starter handle length Triumph 8
Atrus Driver front hard line length Spridgets 2
J Handbrake cable length? Austin Healey 1
T AH 3000 Oil Pressure Relief Valve - Spring Length Austin Healey 4
