TR2/3/3A Weather seal between apron & wings?
GTP1960
Do you know if there should be a Weather seal between apron & wings?
the manual mentions "sealing beading", but I can't find an illustration or part #.
thank you for reading & your comments & advice is appreciated!
TR3driver
Great Pumpkin - R.I.P
I believe they are talking about what became the chrome bead on later cars. At any rate, I've never found anything resembling factory sealing.
I've disassembled many TR3s and never saw anything but the chrome strip. Be sure to have good coat of paint on the inner side of fender and tub.
marv
Kleykamp
I recall having a layer of caulk like/adhesive "stuff" between the mating surface of the fender to the inner fender. It appeared to be a very thin bead of caulk that was "squished" when the fender was bolted down and became very hard/brittle after it set up. I remember it on two '59s but not on the '61 I have now. None of the cars appeared to have ever been disassembled prior to me. I didn't put anything back except, as Marv says, a good coat of paint. It was not thick enough to affect fitting, but was very hard to sand off, short of using a disk sander. It was only along the top, flat surface of the inner fender. If you are talking about the area where the fender bolts into the side of the front apron, then...what Randall and Marv said.
GTP1960
GTP1960
Thx for your comments.
i'll stick with the coat of paint.
(she's having a pampered retirement,[ on my watch, anyways]... never gets wet except for a wash)
NutmegCT Window weather seal repair Restoration & Tools 4
F Replace 1500 Door Fuzzy Weather Seal Triumph 3
RickB Stormy Weather - Hardtop seal? Spridgets 4
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
algot1901 Weather stripping and rubber parts Other British Cars 1
R TR2/3/3A Weather strip adhesive Triumph 11
R TR2/3/3A Weather Gear Triumph 3
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
Rob Glasgow Hardtop Weather Austin Healey 10
R Very Difficult cold weather starting problems! Austin Healey 21
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
KVH General Tech Help With Rusted Weather Strip Channel Triumph 1
steveg Healey hot weather driving observations Austin Healey 2
M_Pied_Lourd TR2/3/3A Storage of Weather Gear Triumph 12
NutmegCT How to remove old weather stripping Restoration & Tools 8
bugedd How is your driving weather? Spridgets 12
Sherlock Jensen FF [in winter weather!] Spotted 5
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
R Choke Not Working In Cool Weather Austin Healey 15
Rut Weather Spridgets 17
M TR2/3/3A Weather question Triumph 9
Trevor Jessie Confused about top down driving weather [off topic] Spridgets 43
M Weather factor Triumph 2
T Soft Top Weather proofing on100 4 Austin Healey 12
E Lovely weather in the UK today Triumph 9
tahoe healey BJ8 wind screen top weather strip Austin Healey 19
A Nice weather, no Sprite! Spridgets 3
DNK Weather Pack Restoration & Tools 0
G TR6 TR6 door rattles/weather stripping Triumph 0
tahoe healey Rendezous weather. Austin Healey 1
B BJ7 Weather Strip Installation Austin Healey 2
dougie PNW Dry Winter Weather Austin Healey 7
memphis Door Window Weather Strip Austin Healey 3
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
PATR8 Well the early nice weather was great Triumph 2
nevets No weather for a drive in the Healey Austin Healey 6
angelfj1 Today's Weather - So nice that . . . . Triumph 5
theleisure Cold Weather, Oil Pressure Spridgets 10
bighealeysource Weather proofing a garage Austin Healey 3
Morris Driving weather! Spridgets 50
T Weather and Transportation - alternate thinking? Spridgets 43
S Jag barely runs in cold weather Jaguar 7
tr7andtvr 280I weather strip source TVR 1
Woodie window weather strips Spridgets 3
B Nice weather - Got some stuff done Spridgets 5
mrv8q Today's weather report... Triumph 68
RickB Cold weather and oil viscosity? Spridgets 8
kodanja Cold weather Effecting Performance? +- Triumph 35
Z Sebring weather Spridgets 2
