Water Coming Out of Exhaust at Start-up
Martinld123
Bronze
by Martinld123
, Yesterday at 07:01 PM
I have owned my 1956, BN2 for 5 years but don't ever remember water spitting out of exhaust at start-up in the morning and for few minutes after then seems to be dry. When it set for a week it looked like a tablespoon of clear water with no smell or taste. No white smoke anytime but still wonder if I have a blown head gasket or something else wrong. The engine has a recent professional rebuild with a MLS head gasket. A couple of those starts were humid days but not all. I am hoping for condensation collecting over night but I maybe dreaming. Any ideas? Thanks Marty
I had as a blog but thought it belonged here.​
Patrick67BJ8
by Martinld123
Water coming out of the exhaust as you describe is normal. Mine does it too as well as several other cars I've owned.
LarryK
By product of fuel burn is water. With car sitting and exhaust cooling the vaporized water becomes liquid and settles in muffler and pipes. Upon morning startup this is really a time that you can see it. If you notice small puddles under your newer cars, not the A/C puddle, it is the water coming thru the joints in the exhaust system. Normal for all internal combustion engines. Now, if it turns to a white smoke while running, then you could possibly have an issue.
BigGreen
In the EU we have "green" petrol with some alcohol ...
Gives even more condensation
LarryK
We have the 10% alcohol and the E85 which produces the extra water also. If he would stand behind someone else's car as they rev it or his newer car, he would see all do the same.
RAC68
Hi Martin,
Although, on initial startup, water is a relatively common substance coming out of the exhaust, I have found this condition to be more prominent when:
1. A grater then spec amount of water is in your fuel.
2. The condensation is being trapped within a section of your exhaust and then blasted out on startup.
I would suggest you:
1. Add dry gas to your fuel to address the possible additional water in the fuel.
2. Check your exhaust for any area that has fallen out of line and could be capturing and POOLING Condensation.
However, I am extending these suggestions, assuming you are not also experiencing a loss of fluid from the cooling system as a result of a bad head gasket or other major engine issues. Keep in mind that although water found in the exhaust as a result of combustion gas condensation may not pose a major problem, it is usually acidic and can, over time, cause deterioration of your exhaust.
Good luck,
Ray (64BJ8P1)
Michael Oritt
What Ray said--definitely.
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
shadowfever Water temp Spridgets 9
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
Lin Heater water valve question Spridgets 2
Editor_Reid Water Temp Gauge Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
Patrick67BJ8 Water filters Austin Healey 16
George Zeck Water Pump ? Spridgets 5
F New water pumps on the market Austin Healey 25
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
C Water flow in heater? Austin Healey 5
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S TR2/3/3A tap water will no antifreeze on new engine Triumph 2
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
dklawson New [to me] Compressor - Water & Auto Drains Restoration & Tools 14
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
F Removing oil and water guage from BT7 dash Austin Healey 17
K For Sale Triumph TR3 Water Pumps for Rebuild Triumph Classifieds 0
D TR2/3/3A TR3 water pump question Triumph 4
JimLaney Drain holes relieve wing water retention? Spridgets 3
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
