walnut display cracks
simpzimmer
My wooden display panel is cracking. The varnish "I guess" is cracking and flaking around the edges. Should I just leave well enough alone or can it be sanded and revarnished. Has anyone else had this problem and has anyone found a remedy?
CraigFL
When my dash cracked like that it was so bad it lifted up the veneer. I ended up making a new solid hardwood dash out of rosewood.
If the veneer is still good (not wavy) you can re-varnish. If it's seperated, but not yet wavy, use some gorilla glue or elmer's Probond (follow the directions on the bottles - applying a dab of water before gluing) in between the layers and clamp them together tightly... Then revarnish. Wood is pretty easy to work with, don't let it run you off if you've never worked with it before.
jlaird
Ahh, seven coats of varnish or three of the modern stuff, well sanded between coats and it will look like a table top.
Not a difficult thing, check your local boat yard. They do lots of varnish stuff.
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
J Walnut veneer for the dash, Look what I found! Austin Healey 12
TomMull replacing walnut veneeron the dash Lotus 17
P BN2 Walnut Steering Wheel Austin Healey 10
B Walnut panel replacement Triumph 8
S Spitfire 74 Spitfire instrument panel, Walnut or Teak? Triumph 5
A General MG 2022 Car Display Geelong MG Car Club MG 2
Guido36 Healey 3000 cutaway display engine Austin Healey 12
Michael Oritt Display ads in posts? Austin Healey 2
Boink Display at Portland ABFM Rover / Land Rover 2
Editor_Reid Healey Hundred Needed for Car Display in Arkansas Austin Healey 0
Shinsen774 MGB Need MGB LE for Show Display in Virginia 9-20-09 MG 6
Twosheds HSTRL Static Display Reopens Triumph 0
ncbugeye Display of Restored Classic Cars in Raleigh NC Austin Healey 6
ddrumman Login name vs. display/username name. MG 22
S Tiger Window Display.......................... Sunbeam (Rootes) 4
G Overdrive display light Triumph 8
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
matmire rocker arm stress cracks? advice please. Spridgets 2
B ā€˜78 Midget Fender Cracks Spridgets 6
CJD TR2/3/3A Low Port Head Cracks Triumph 36
Rob Glasgow Motor Mount Cracks Austin Healey 10
T Trailing Arm Cracks Triumph 23
davidb BJ8 small cracks in shroud Austin Healey 1
Lynn Kirkpatrick Cracks in '68 banjo steering wheel MG 9
aeronca65t suspension cracks Spridgets 14
T The windshield is in...no cracks.... MG 4
MTribe How to repair rust pin hole and cracks in floor? Triumph 25
C Welding Alum. shroud cracks, and hole repair Austin Healey 7
E 74 Lotus w/ minor/micro cracks in piston sleeves Lotus 10
T Cracks in Alpine blocks Sunbeam (Rootes) 3
