very early gear wear
TexasKnucklehead
I have a new chain and both sprockets, and finally have the cam to crank timing set properly. I must have turned the engine over by hand 50 times. When I went to put on the timing cover, I noticed wear marks on the teeth of the crank gear. I had to look closer to believe it. It's hard to get a good picture, but I've attached two. The top sprocket looks fine and so does the chain. Normally there would be more oil in there, but the chain is not dry and I didn't expect to see wear already. Is this normal, or should I give Moss a call -or maybe try another crank sprocket?
TR3driver
Great Pumpkin - R.I.P
I'm not sure calling Moss will help, but I'd definitely do something. Otherwise it could wind up looking like this:
bgbassplyr
Looks like the manufacturer forgot a very important step in the manufacturing process. That gear will probably last a good five minutes with the engine running. Maybe even less. Moss should be informed, IMO.
poolboy
Sprocket alignment. That's what it looks like. The chain is shearing off the side of the teeth.
T
TexasKnucklehead
I do have a Bently (1976 edition), but my page 136 is an engine diagram.
But that comment and the 'alignment' hit a nerve. I know somewhere I saw where you're supposed to check the alignment of the sprockets, but can't find it now. And know I didn't do it. So I took off the cam wheel, pulled the chain, and pulled the crank sprocket and put it back on with the stamped lettering towards the engine and it looks so much better. If something can go together two ways, guess which way I do it first?
The teeth are not centered in the crank wheel.
I'm glad I noticed it now...
mallard
It's very easy to check. Use a good straight edge and put it on the flat face of the larger gear and try to slide a feeler guage under the straight edge on the smaller gear. Try to get it so you can't put a feeler under the straight edge. Make sure you keep it square. To get it correct you may have to use some shims washers behind the gear. When I took my engine apart there were two shims, with news gears it only required one.
poolboy
Yes shims or as Haynes calls them "packing washers" placed behind the sprocket on the crankshaft. See Haynes Chapter 1,Section 51.
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
JPSmit Very Early BE Spridgets 5
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
Bayless The very simple rotisserie Spridgets 3
G TR4/4A Flasher Unit...VERY hot Triumph 10
R Very Difficult cold weather starting problems! Austin Healey 21
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
drambuie The nasty boy Healey version may very well be more true to the original intent! Austin Healey 14
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
andrea Very strange austin healey 3.9 Austin Healey 5
P gearbox shifts very badly Austin Healey 7
T TR2/3/3A Air dam seems to be working very well Triumph 5
W Very respectable restoration Spridgets 9
RJS TR4/4A Clutch Fluid Very Dark After One Year Triumph 5
tinman58 TR5/TR250 Very stiff rear end Triumph 27
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
bighealeysource Best way to remove very fine scratches in chrome windshield frame Austin Healey 1
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
drooartz MGB Sometimes I'm very proud of my work... MG 6
John Turney UPDATE: Up-date on a Very Expensive Healey Austin Healey 8
D BT7 Hard top back window that is very cloudy Austin Healey 5
NutmegCT Buying this will sure make someone *very* happy. Other Cars 14
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
pkmh HBJ8 Steering Wheel Repair Experiment - VERY GOOD. Austin Healey 7
tr7andtvr Very Disappointed with Lotus at Indy 500 Lotus 13
swift6 A very wild morning drive... Triumph 34
C One very cool Allard Other British Cars 2
C A very pretty little Elva MkVII Racing 1
RickB VERY OT - what I'm doing while on sick leave... Spridgets 10
JPSmit Very cool rat rod! Other Cars 3
C The Story of a Very Special Jaguar Racecar Jaguar 2
JPSmit Need a MOWOG and very confused Spridgets 13
C Very nice Triumph-Powered TVR 2200 Special Racing 9
J Anyone interested in very original 1958 Bugeye? Spridgets 1
RickB Needo to install a very loud horn - freeway 'fun' Spridgets 27
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
V Very nice Jensen Healey on eBay Other British Cars 10
14dna Very Sad Sight Spotted 0
