HBJ8 Steering Wheel Repair Experiment - VERY GOOD.
pkmh
Hello all,
My last post here a few weeks back made reference to the removal of my steering wheel for the Healey in attempts to understand more about;
A. What may cause my signals not to work;
B. I wanted to remove the cracked portions of the steering wheel at the third points and restore by using old 78 records [dust] with glue and;
C. Repair the adjustable locking hub for the telescopic portion of the wheel.
I am still in the process of determining the cause of my signals not working, but all wiring within the upper stator tube was not the cause or so I believe, although I had to mend the sheathing to one wire. I will probably need to purchase another flasher unit to test further.
As for the adjustable hub, that is now working as designed, but only after many trials of grinding down the interior bakelite surrounding, resulting from shrinkage over the years and locking up the wheel (or in my case, the hub fixed tight in an open position and the wheel never locking at all). So, most of the inner bakelite surround is still within the hub and I figure I leave as much there instead of removing all.
Finally, the experiment of using pulverized record dust and Elmer's Glue worked well enough to my satisfaction and the final picture will follow soon (sorry, new computer operating system--don't know what I'm doing). I also incorporated wire "rebars" to keep the plastic remains intact as much as possible as well as the glue~dust mixture together as well.
All but the final product is posted here and that photo will be posted soon.
FWIW, I decided to use the Elmers [wood] glue because of the ease of mixing the dust with a more liquid base. It meant having to apply in layers at a time and rough sanding as I went. The curing process also took time and may still take longer before all cures rock hard. I experimented with epoxies and other cements but would not bond well with the dust, and I thought about having contact with Elmers vs. cements, etc. Seems to be a more safer solution.
Again, I have no idea how this remedy will hold up in the extreme heat and cold and aside from the slight difference in textural finish, but only resulting in a dull glossy finish vs. to the surrounding existing rim's glossy finish. The results are very good. Even the feel feels the same. If this solution does hold up, then the textural finish will only improve over time, increasing the glossy feel, after constant finger contact.
Enjoy the photos, so far....
Paul
Here are some most recent shots taken today...
HealeyRick
Interesting choice of repair materials. I tried to repair mine using epoxy, but it recracked after a while. Hope you fare better. If it holds up, maybe you could spray the whole wheel with an epoxy paint so it would be a uniform color. Best of luck.
(I took the easy way out and purchased a Lempert wood wheel and never looked back).
pkmh
pkmh
New photos added above...
Yes, Rick,
I hope I do fare better or enough to get by without the wheel cracking again.
In attempts to blend in the finishes of the repair, I am going to try to use that "Rit" clothes dye and see how that goes. When I fine sanded the new surfaces, they blended perfect with the rim, but as we know, the rim is not a flat matted finish.
Knowing what I know now, I should of made a more consistent design and better conceal the grooves I made for placement of those rebars I inserted.
But being what it is, I am much more pleased to have smooth surfaces rather than gaps or dangerous splines cropping out.
Then one day, after all other important issues are resolved, I'll go back an invest in a new wheel.
Paul
pkmh
pkmh
Thanks for that, too. After I darken those third points some more, the finish will greatly improve.
I already tested using those black laundry markers and the overall appearance was greatly improved.
I'll try some black clothes dye next.
Keoke
Yes you may get by without the wheel cracking. However, I do not think your repair will stand up to heat. Most adhesives soften when exposed to heat.Looks good.
You might get by if you purchase awheel cover to protect it from sun light,--Fwiw--Keoke
nevets
The real test will be how well the repair holds up with temperature shifts. It may expand / shrink at a different rate than the surrounding plastic material, in which case all the joints will become visible. If you opt to paint the wheel, then you can use bondo or some other resin-based material as filler, which may be more dimensionally stable.
It's a creative solution. I hope it works out.
pkmh
pkmh
Thanks for the words of encouragement...
The one thing I notice with this "mixture" of [78] record dust and wood glue is, there seems to be some resilience when I press into the repaired areas a bit with my fingernail. A slight indentation is noticable, but returns to normal after a brief period of time. So this may be a good thing in terms of dealing with weather extremities.
But I still feel that in time, this will (or should) harden to a rock hard substance and why it hasn't yet, even after a few weeks in place, remains a bit of a mystery to me.
But so far, it hasn't cracked or seperated, yet. I will be able to improve the finish, whether it be with clothes dye or some other (maybe India ink). Right now, it is a whole lot better than it was before.
Just in case one wishes to experiment with this idea further, there are at least two types of those old 78 records out there and the one I stayed away from is the type having this embedded paper like sheathing which must of served as a means to strengthen the record against breaking through normal use. I stayed away from that type for the color of that paper substance was lighter than the surrounding black material which may of compromised further the overall repair finish. Consistency of workability was another concern I had.
Thanks,
Paul
pkmh HBJ8 Tach Conversion Austin Healey 3
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
W Steering Arm Colors Spridgets 1
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
