Unusual gearbox identification
Talonaer
Need some help identifying this ? unusual gearbox and then thinking how can fix it..
1960 Mk1 sprite
modified in period by BMC dealer in
948 +60'' flat tops
thick engine back plate
9 spring borg and beck pressure plate
mated to:
rib case gearbox that I cannot identify....
layshaft: HS14 T
1st Motion Shaft OWOG G-4n
3rd Motion shaft cy4u
Case: C865 22g121
Front palte 22g118
Side plate 22a170
Re,pte 22a480/VAF 3
Selector 22a478/VAF10
its a helical set of cogs but the ratios dont match anything I can find anywhere
1st
Lay shaft 13 teeth, 3rd Motion 32, Ratio 2.461
2nd
Lay shaft 19 teeth, 3rd Motion 28, Ratio 1.47
3rd
Lay shaft 24 teeth, 3rd Motion 23, Ratio 0.958 ?!?!
I may well be calculating the ratios wrong but this is what ive read elsewhere seems to suggest to do?!
The first motion shaft has 28 teeth and the layshaft gear 19.
Unfortunately the 1st and reverse and corresponding cogs on the layshaft have had it (Was jumping out of reverse thus why stripped it)
any help on
1) identifying it
2) suggests what to replace with: could I put a new 1st, 1275 layshaft and reverse idler gear in it? or completely incompatible and thus needs a complete new set of cogs....
Pictures at:
https://sebringsprite.blogspot.co.uk/2017/12/gear-box-troubles.html
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
roscoe An Unusual Healey Mission Austin Healey 2
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
TomMull Somthing affordable and unusual for the car shows? Other Cars 1
Brinkerhoff TR4/4A Belgium built TR4A, is a bit unusual ! Triumph 16
Bob Claffie Spitfire Unusual parts Triumph 1
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
T TR2/3/3A Unusual Tires On TR3 Triumph 24
catfood Unusual BN1 Austin Healey 12
B General TR Unusual banjo pieces for brakes? Triumph 3
V TR2/3/3A Unusual Engine Number Triumph 5
angelfj1 TR2/3/3A TR2.5 - Unusual wheels and mirror Triumph 11
K Most Unusual Bodge or Repair by a PO? Triumph 21
DNK So that's unusual Lotus 6
angelfj1 Unusual Air Filters Triumph 28
angelfj1 TR2/3/3A A most unusual TR2! Triumph 17
angelfj1 Unusual TR Commission Numbers Triumph 7
G Something unusual at the station today Other British Cars 0
tony barnhill Unusual Things Found in Your Car MG 29
AngliaGT Unusual Sight Today..... MG 8
jlaird My unusual day. Spridgets 23
NutmegCT unusual starter noise Triumph 7
A Unusual 1963 Honda S600 Sports Car Other Cars 20
jlaird Unusual for me Spridgets 10
tony barnhill So, Where's the Most Unusual Place You've... MG 43
Sherlock Unusual automotive sightings Other Cars 2
Sherlock Unusual cars in movies - news flash Other Cars 3
Sherlock If a Mini isn't unusual enough for you... British Motor Corp 17
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
