carcrazie51
Trevor,
Yes my kit uses a Marina hub. They are available in the UK as blanks that can be machined to what ever bolt pattern needed. A stock Marina hub or the Morris conversion hub will not fit on the Sprite/Midget. The kit that we make has tapered roller bearings in the hubs along with bearing spacers. It is fully assembled and bolted to the rotor when you purchase the kit. This then becomes a slide on, tighten the nut and go, very easy install.
