TR6 TR6 steering rack rebuild questions
ichthos
Hello,
I recently had to rebuild my steering rack. It was just about as much to have TRF rebuild as it was for the parts, so I had them do it. The outer tie rods were shot, and I wasn't sure about the inner tie rods. The pinion gear was so loose that I could spin it with my fingers. Now it is much tighter - I have to attach the union to get it to turn. I have two questions: 1)Do you normally have to add any oil to the pinion after it is rebuilt? 2)The pinion doesn't turn real smooth. I can feel the pinion mesh as it turns with the rack - is this normal? I am hoping to have this car up and running this weekend after almost a year of sitting in my garage, and I don't feel like waiting to contact TRF next week. Any help would greatly be appreciated.
Kevin
DNK
Re: TR6 steering rack rebuild questions
Kevin- Somebody should be there today
alfa33047
I have torn apart, inspected, cleaned, greased and reassembled 3 steering racks in the last two weeks. I have found that when I reassemble the racks (if nothing is badly worn) I have found that I too find the splined steering stub is tight and I need to slip on a U-joint and turn the steering. If you find the stub loose, you will need to disassemble and reshim your stub shaft. Just for general information some of the thing that I have found out about Triumph rack and pinions. Spitfire, TR-4, Tr-6s all use the same rack, In having bought about 25 in the last 2 years from known cars, I can find no differences. All but one has been 3 and 1/2 turns. I have only found one 2 and 1/2 turn rack from a late Spitfire. The 2 and 1/2 rack that Moss sells is not made like regular Triumph racks, I removed a boot and it appears that the inner tie rods can not be removed or rebuilt. I put Rack and Pinion steering on TR-3s and have to be able to remove the inner tie rods to shorten them. This is my obsevation. Good luck, Bill C. Mesa, Az
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
P TR6 Steering Rack TR6 Triumph 2
G TR6 TR6 Steering Rack Mounts Triumph 17
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
M TR6 TR6 steering rack disassembly Triumph 5
I TR6 TR6 steering rack/wheel allignment help Triumph 2
F TR6 Replacing steering rack and mounts TR6..help Triumph 10
SCguy TR6 TR4/TR6 Steering rack question Triumph 9
tr6web TR6 TR6 Steering rack - tie rods and more... Triumph 3
B TR6 TR6 Steering Rack boots Triumph 6
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
I TR6 TR6 steering wheel refitting Triumph 2
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
B TR6 Oil in a grease gun for TR6 lower steering swivel? Triumph 16
B TR6 Tr6 Steering Wheel Triumph 3
P TR6 TR6 Steering column clearance Triumph 4
arizonamike TR6 Nardi steering hub for TR6 ? Triumph 0
Coyote1 TR6 74 1/2 TR6 Steering Column Support Triumph 4
O TR6 TR6 Steering Lock Triumph 4
M TR6 TR6 Steering wheel refinishing Triumph 3
SkinnedKnuckles TR6 TR6 Steering Flex Coupling Triumph 7
hondo402000 TR6 TR6 Hard steering Triumph 6
hondo402000 TR6 TR6 Hard Steering Triumph 3
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
I TR6 69 TR6 steering column help Triumph 2
I TR6 As the World turns -TR6 steering column bushings Triumph 6
I TR6 TR6 Steering column questions Triumph 1
N TR6 Installing Flex Coupling for steering TR6 Triumph 5
G TR6 Can finally drive the TR6 with a steering wheel Triumph 7
R TR6 TR6 Steering wheel advice needed Triumph 6
jjbunn TR6 Shift knob to Steering Wheel, TR6 Triumph 27
B TR6 TR6 aftermarket steering wheel Triumph 9
B TR6 Where/How to straighten steering wheel [TR6] Triumph 8
G TR6 "Notchy" feel in steering. TR6 Triumph 19
WidespreadPanic TR6 TR6 Steering Wheel Removal Success Latest w/pic Triumph 26
T TR6 After Market steering wheels - TR6 Triumph 3
N TR6 TR6 Steering lock and ignition Triumph 1
padjo TR6 TR6 Steering Lock Triumph 7
hondo402000 TR6 TR6 hard steering Latest/ scrol down to see origin Triumph 3
hondo402000 TR6 TR6 Hard steering Triumph 8
F TR6 TR6 Steering Column Triumph 6
Paulus TR6 TR6 Steering Column Search Triumph 5
SpannerMan TR6 TR6 - steering stop [lock stop] adjustment? Triumph 5
Alan_Myers TR6 Momo or Nardi steering wheel on early TR6? Triumph 6
M TR6 play in upper part of steering shaft tr6? Triumph 2
mailbox TR6 loose TR6 steering Triumph 3
