TR6 Shift knob to Steering Wheel, TR6
jjbunn
I have my eye on a '71 TR6. This car has a new Moss transmission in it. What puzzles me is that the gear knob is very close to the rim of the steering wheel. It doesn't actually touch it, but it's close.
Is that normal? What might be the problem?
Here's a photo:
roofman
I have a non stock wheel ( 14" ) and the shifter gets to about 3" away at closest point. ( 72 TR6 ).
roofman
Maybe th PO had short arms?
jobster
this is definitly not the stock shifter. The stock one is shorter. Simply remove it and replace it with a new stock one. Should be easy to get from all the well known parts-suppliers. Whatever the DPO did, it may have suited him well, but to me it looks plain stupid and not very comfortable.
jjbunn
jjbunn
It didn't appear so, when I met him ... maybe a prior PO!
While I have the attention, here are a couple of things that are puzzling me on the car.
1) There is a small notch in the top of the panel just behind the passenger door. Is it normal?
2) What is this foot-operated switch at the left hand side of the driver's footwell for? I'm guessing headlights.
By the way, this car was first registered in Germany. It's currently blue, but judging from the colour in the footwell was originally red.
TR6oldtimer
There may be a bigger problem lurking under that notch behind the passenger's door. The rear and front fenders should have a well defined seam. It appears that the car was repainted at some time, and who ever did it used body filler to seal the seam. Look for rust under the fender seams and from under the rear deck at the inner fender well.
The original color may not have been red and what you are seeing is the red primer.
The switch on the left is a dimmer switch for the high/low beams. Welcome to old cars.
RomanH
The switch on the floor is the headlight dimmer.
The notch is supposed to be covered by an piece called the B Post Finisher. It's a small chrome cap.
jjbunn
jjbunn
Thanks for the replies.
The red paint being primer makes sense: the blue paint job was too good and original looking to be a respray.
Regarding the B post caps, the curious thing is that the opposite, driver's side doesn't have a notch:
roofman
Look at part 108 and 109 in the Moss Motors catalog under rear body panels, or part 21 & 22 in the Victoria british catalog. These butt up to the rear fenders, and there is a seam there. In the first set of pictures you see a 1" notch. That is where the seam should be. The filler came out in that picture, and not in the driver side picture. this is shoddy body work at best, and hiding big time rust at worst. Originally Triumph probably used a seam filler "caulk" or similar. To fill these areas with bondo would suggest something negative has been covered up in a common rust prone area.
The chrome caps go above the area with the seam at the top inside portion of the turned down edge.
TR6oldtimer
Julian, That split looks to be exactly where the fender meets the body. As stated in a previous post, TR6's did not have sealed fender seams. Whatever was used to seal the seal has come undone.
(Click on the thumbnail to enlarge)
jjbunn
jjbunn
I see what you're talking about, but on the car I'm looking at there is no trace of a seam in that position on either side.
Here's a large photo of driver's side. If you look down in the door jamb there is no seam visible.
https://farm2.static.flickr.com/1096/1280794628_236a1758cb_o.jpg
Also, if you look at this, a little further back, the seams are quite visible. The front/back seam doesn't extend forwards.
https://farm2.static.flickr.com/1224/1279929029_434a6e04c8_o.jpg
Is it possible that the cars made in Belgium used different pieces?
cyaker
The red is too red, the primer is much duller in tone. I say it has been painted. The chrome finishers are missing on both sides. I am not sure why the notch the rust I would expect in that area would be the 'b' pillar itself.
RomanH
Julian,
Forget what I said earlier, I misunderstood the question. Everyone who said that that is the seam for the fender is correct. In the last photo you posted you can see the seam run forward along the trunk lid to the rear deck. That seam continues up along the forward deck portion. It does appear that someone has filled it in.
In that second picture I also noticed that the top is installed in a strange manner. The top should be fitted over the body work and attached to a retainer bar then the bar is bolted to the body. On the one in the picture it appears that the top is stuffed under the body work. /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
G
Julian, where do you find these cars? It's almost as if you were a gluten for punishment. That car has more problems than you need. Just peering inside the door one can see rust abounds. Stop looking at basket-case TR6s, they will cost you way more than a driver that has been already fixed up and might need additional restoring later.
I have a friend that totally restored a 67 TR4, but he started with a basket case car, figuring that he would save money. He overlooked a solid running TR4 because the cost was about 2K higher. After hundreds of hours of welding, beating, replacing, stretching and generally killing himself, he has a super-nice restored TR4 that he could have had for a lot less had he bought the more expensive car. He realized his folly afterward.
I realize every story is different and people have different priorities and different budgets, but the old adage still is valid, buy the best you can afford. Just stay away from cars that have weird body repairs. Engines are cheap in comparison.
jjbunn
jjbunn
Hi Bill,
Which photo are you referring to where rust abounds?
There is some rust in the passenger footwell, and on the rear valence of this car. Other than that I couldn't see anything serious. The underside is clean and the frame looks good.
The adage "buy the best you can afford" is one of those pieces of advice that sound wise but actually are of little practical use, I'm afraid! I agree that saving 2k on a car that needs 2k or more of work is a bit daft, but that does depend on whether you enjoy doing the work. My situation is that I'm looking to buy a car to work on, not a completed car to drive around.
I'm still puzzled by these seams, or lack of them. Why would somebody fill those seams and repaint on both sides, without filling the other rear seams?
Anyway, many thanks for the warnings: I appreciate them, and like to go in with my eyes fully open /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Julian
roofman
Because this is a common rust spot, and filling them is easier than taking the car apart to put in those 2 pieces. Just spread the bondo, sand and paint and it looks better to someone who is A). trying to sell, or B). someone who doesn't give a rats behind.
jjbunn
jjbunn
To help me understand, are people saying that in this photo:
https://farm2.static.flickr.com/1073/1295677257_3246cf38fc_o.jpg
the yellow arrow is pointing to the filled continuation of the seam running from the right hand side of the photo?
I guess I'm way out of my depth here because this seems most unlikely.
jobster
unfortunately for you, yes that's where the seam is supposed to continue. I am really curious why you bought this car because to be totally honest, from the pictures this car looks like it has potential to become Cripty #2
tomshobby Steering wheel, dash, and shift knob. Triumph 20
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
S TR2/3/3A Gear shift knob Triumph 8
C For Sale Brown Ebony Shift Knob Other British Classifieds 0
TomMull TR2/3/3A shift knob Triumph 19
J TR2/3/3A such strange thread on gear shift knob Triumph 12
AUSMHLY Wooden shift knob, how to refinish Austin Healey 35
U Shift knob reference? Restoration & Tools 11
tomshobby Shift knob insert is missing Spridgets 12
drooartz 5-speed shift knob Spridgets 19
af3683 TR2/3/3A TR3 Original Gear Shift Knob Triumph 16
R Burl Shift Knob[?] Austin Healey 17
jvandyke fancy wood shift knob install Spridgets 2
pjsmetana How do I get Shift Knob off? Triumph 2
AUSMHLY Shift knob thread for BJ8 Austin Healey 6
NASpecMGB WTB Midget/Sprite orig shift knob, 1971 or earlier Spridgets 2
B Shift Knob for my 79 Midget again Spridgets 2
Bruce_B Triumph Overdrive Shift Knob and Lever Triumph 9
B anyone used a Gearflix shift knob? Triumph 7
PeterK TR2/3/3A TR3 Shift knob lock nuts? Triumph 9
timbn2 how big is a stock BN2 shift knob? Austin Healey 2
AUSMHLY Got shift knob? How's yours feel? Austin Healey 4
timbn2 looking for a bn2 shift knob.... Austin Healey 4
SCguy TR4/4A TR4 gear shift knob Triumph 13
timbn2 BN2 shift knob question... Austin Healey 1
gsalt57tr3 Gear shift knob idea Triumph 7
kyreb1862 Gear Shift Knob Removal MG 7
RSMTR8 Wedge TR8 Gear Shift Knob Triumph 7
nevets Disappearing shift knob graphics Austin Healey 7
Newkie Now, Im looking for a wooden shift knob MG 6
MrPandy TR6 Question about TR6 gear shift knob Triumph 15
M free wooden shift knob Triumph 1
S Gear Shift Knob Jaguar 3
aeronca65t "Lucky" Shift Knob Other Cars 5
C Blue MG Logo Enamel shift knob MG 1
J 73 Gear shift knob MG 0
T Spitfire Shift knob/ late Spitfire Triumph 2
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
S MGB 78 MGB cannot shift into reverse MG 3
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
WHT Center-Shift Bellhousing Austin Healey 10
DrEntropy Shift rod seal in an automatic? Jaguar 7
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
