TR2/3/3A TR3A Horn Attachment Hardware
angelfj1
This photo was taken in the late 90's. You will note both a thick flat and lock washer for each of the two horn attachments. What I can not recall, is the thick washer used as a spacer under the horn and the lock washer on top under the head of the 1/4-28 bolt. Sorry for the poor quality photo - digital cameras have come a long way in 12 years.
Incidentally, the parts catalog shows a standard flat and lock washer on top, but I am fairly certain that what is shown above is the original hardware.
TR3driver
Great Pumpkin - R.I.P
Where do you see that in the SPC, Frank? Mine has no illustration for the horn attachment hardware, but lists the washer as a WM.0093, which according to the standard hardware catalog should be "10G", or about .128" thick (assuming the 10G refers to 10 SWG).
Anyway, it's my belief that the plain washer goes between the horn & body, while the lock washer goes between the bolt head & horn bracket.
angelfj1
angelfj1
I missed the "10G" and figured it was regular thickness. Here is a good reference.
FLAT WASHER THICKNESS TABLE
I have been able to confirm that the thick washer goes underneath, that is between the sheetmetal mounting surface and the horn bracket. The lock washer goes on top under the 1/4-28 bolt head.
Thanks
TR3driver
sp53 said:
Hi Frank I am working on that same area. Would you know a supplier that carries the spacer piece?
I believe TRF has them listed, under WM93.
sp53
Thanks Randall for your help. I just have trouble finding the little things like that on the TRF site. I put the part number in and it showed up and the next time I tried, it said no good. I must be opening the wrong page. Is there another catalogue on their site other than the mini catalogue?
Steve
vivdownunder
Frank, I've got a spare of one of the original 1/4" flat washers that went beneath the horn mount bracket. It is 5/8" diameter x 1/8" thickness.
Regards,
Viv.
TR3driver
Not really, just the parts database (which is where I go first on the TRF site). What Charles told me, many years ago now, was that I needed to get a copy of the factory Spare Parts Catalogue and order from that.
They sell both paper and CD reprints; or you can download one from here:
https://docs.google.com/leaf?id=0B2H2NJt...2ODQy&hl=en
sp53
I think I got Randall, but I am not sure. I down loaded the catalogue and found the horns on page 66 and found that part number wm93. Next I went to TRF parts data base and plugged the part number in and it came up with a price, I think 28 cents. Is that how you do it? I could not find any pictures however? The part is most likely the right one, but I am not totally sure.
Steve
sp53
I think I got it Randall, but I am not sure. I down loaded the catalogue and found the horns on page 66 and found that part number wm93. Next I went to TRF parts data base and plugged the part number in and it came up with a price, I think 28 cents. Is that how you do it? I could not find any pictures however? The part is most likely the right one, but I am not totally sure.
Steve
Moseso
TRF carries a lot of parts that have never been pictured in a catalog.
If you search their parts database, using the S-T parts book number, and they show it as a currently available part -- it's probably the right part, whether pictured or not.
TR3driver
toysrrus
angelfj said:
Thanks Viv, et al. I made them up on the lathe.
Hi There anelfj,
Would you be able to make "4" of them for myself?
Thanx, Russ
sp53
I guess that is one more apology I have to make to TRF. I could not understand their system and figured Moss had the only idea that had any depth.
Steve
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
angelfj1 TR2/3/3A Tr3a - no horn Triumph 4
B TR2/3/3A TR3A Horn Issue Triumph 12
Tinkerman TR2/3/3A TR3A Horn Wiring Problem Triumph 2
Tinkerman TR2/3/3A TR3A Post 60,000 Horn orientation Triumph 4
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
