TR5/TR250 TR250 Up-date, engine compartment painted
glemon
TR250 Update, engine compartment painted
I took the plunge and ordered some Signal Red paint, I thought about royal blue, always liked the color, but it started out life red, so will finish red.
Decided final fitting and fettling of rockers/A/B Pillars/ doors should be done with the motor in place, didn't want to put the motor in twice, so painted the engine compartment, including the new metal put in the hole that had mysteriously appeared where the battery goes,
I must be kind of a visual guy, because the shiny red paint is an inspiration, most all the major stuff is rebuilt or checked and OK'd including the motor, transmission, carbs, generator, alternator, most of the hydraulics except the brake booster.
My major projects, the seats, final paint prep, and the rear suspension and driveline, also have to build the adaptor to fit the J type O/D/
But at least things are coming along, as I said, the shiny paint makes me feel like I am getting things done.
TR4nut
Re: TR250 Update, engine compartment painted
Outstanding job! You are going to really appreciate it when everything gets bolted back in.
Randy
Brosky
You will not regret doing it the right way.
Now for the hard part. You must give the paint enough time to cure and then cover everything painted with soft cloth or masking paper when you put things back in.
Is the body painted yet? If not, you will want to make sure that everything is sealed off underneath to prevent overspray from entering the engine compartment and spoiling that beautiful clear coat.
glemon
glemon
Brosky, yes, have thought about both those things, body isn't painted yet, overspray will be an issue, as will getting it back together without scratching things up, am thinking of taping some towels to the inner wheel wells to keep them a little safer in the process.
There were times recently when I didn't think I would ever get it all done, still a long way to go, but the progress on the engine compartment is good for moral.
Would like to have it done before the snow flies, but I know next year is a much more realistic scenario.
tdskip
Nice work! The engine compartment looks great.
What did you use to spray it with?
tdskip
DNK said:
tdskip said:
...What did you use to spray it with?
Paint Sprayer
Should have known that was coming Don, should have known...
Let me be more specific - did you use a conventional gun, Preval, or Turbine sprayer?
glemon
glemon
I assume you are asking about paint, standard HVLP gravity feed gun, paint is a single stage urethane enamel from the Autocolor Library Restoration Shop line of paints, it was much cheaper than the local body shop and they offered Signal Red, so thought I would give them a try and see what I thoughr of it by using it to spray the engines compartment.
I think the paint is fine, I had to add a little bit of extra reducer to get it to lay down as wet and smooth as I wanted it, but it was hot in the garage and I think a little beyond the reducers temp range.
The only thing I noticed I was surpristed it was still tacky to the touch for quite some time after painting, like 5-6 hours or more, thought maybe I mixed it wrong, but made up another batch and had the same result.
Was a little humid could some water moisture in the paint cause this, didn't create any problems, dried fine eventually, just took a little longer than has been my experience with other paints.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The only thing I noticed I was surprised it was still tacky to the touch for quite some time after painting, like 5-6 hours or more, thought maybe I mixed it wrong, but made up another batch and had the same result.[/QUOTE]
Remember what I said about the hardest part was coming up in letting it cure? The longer the better.
Now you can get started painting the engine to make it look good in it's newly remodeled home.
Or as some would say, you can begin to add the bling.......
glemon
glemon
Well Paul since you brought it up...it actually looks a lot better in the flesh than in the pic, the digital photos don't seem to compliment the black paint or the chrome very well. I covered it with the plastic trash bag while I was painting the engine compartment.
DNK
Before you stick that motor in that nice compartment.
Ditch that oil canister and install a spin on.
glemon
glemon
You know I read the spin on would be better for the anti return function, giving better oil pressure on start up, but the old filter and pump were still full of oil when I took them off the engine after sitting idle for months (and the crank didn't need anything but a polish after 90,000+ thousand miles) so the stock setup can't be too bad.
DNK
Just when you go to change the oil.
rooster
Hi,
I noticed in your first picture that you were using newspaper for masking. You might want to be careful about that, because the ink in the newspaper can stain into the paint, and ruin your paint job. You can get proper making paper at your auto parts store or use brown craft paper (not sure which is cheaper). Plastic is ok as long as you don't put right up close to where you are painting, as the paint can run off the plastic to where you just painted.
cheers.
glemon
glemon
As far as the spin on vs. cannister, I used to curse the cannister, but I have been changing oil on British cars with cannister filters for so long I have just kind of gotten used to it. As far as the newspaper, yes, I had heard that too, I used it to cover the windsield which will eventually have the glass replaced and get repainted, and the frame, which I wasn't too worried about, but appreciate the tip, and will upgrade to the right stuff when I paint the body, Greg
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
B TR5/TR250 Registry for TR250's? Triumph 1
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
RobT For Sale Triumph TR250 - $32K Triumph Classifieds 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
T TR5/TR250 Original TR250 sun visors Triumph 0
Marvin Gruber TR5/TR250 TR250 Alternator Triumph 13
glemon TR5/TR250 TR250 Prototype Triumph 10
flylear45 TR5/TR250 TR250 resto project log Triumph 12
M TR5/TR250 No spark on TR250 Triumph 17
David Townsend TR5/TR250 New TR250 Limited Edition Print Triumph 0
H TR5/TR250 TR250 rebuild question Triumph 3
