todays clutch report
zimmy
with clutch in the slave is fully extended and firm...
i put the car on stands in the back...started it up and tried the rev it up then brake(hand) approach....just dies like it should.........
tried 1-4 gears with no results other than it wants to jump outta first whe revved up with the wheels off the ground...
next........
jlaird
I'm afraid I would pull the engine and do it right. Sorry.
IF you have an engine hoist, you can pull the engine and tranny, replace the clutch and have it put back together in a day (even the first time)
Somebody else might have a suggestion for freeing the clutch. There might be something you can spray in there to help release it, but I don't know what it would be.
jcatnite
Be careful. I scratched my pressure plate up poking around in there with a screwdriver. I should have known better but I didn't think I had the blade in as far as it ended up being. Just my $0.02
JC
jlaird
27 bolts to remove engine.
zimmy
zimmy
i dont have a hoist and if i pull the engine id rather put in a new clutch which i cant afford right now.....someday
jlaird
That's it, and he wasted a lot of words to make it clear.
zimmy
zimmy
ive read that 10 times ....this has been a pain in the butt ...but i will make it happen whatever it takes...
thanks for the "already been there support"...
i also read if you depress your pedal during storage this problem isnt likely to happen...i use a retractable aluiminum curtain rod as my clutch man....never says a word ; ) ......zimmy
jlaird
Only ever had it happen one time when I stored the bug for the winter, drove it daily the rest of the time, 20+ years.
Platinum
The "Shock treatment" has always been a last resort for me but I have used it. Warm the engine up to temp first, as that seems to help a lot when trying to "snap" the surface tension of the disk-to-flywheel. Good luck.
sparkydave
[ QUOTE ]
[/ QUOTE ]
Be aware, if you do leave the clutch depressed, that most likely the fluid *will* find a way past the seals, and brake (or clutch) fluid does a nice job of taking paint off. Better plan: Depress the clutch, and wedge a block of wood between the clutch arm and the bellhousing. Don't leave the hydraulics under pressure, because the fluid will leak out. Hint: This is why my dad can't leave the hydraulic power windows on his '47 Lincoln in the "up" position for more than a week at a time.
piman
Hello Zimmy,
when I have had a stuck clutch, I've never bothered with jacks etc. I just warm up the engine, stop it, engage first gear, clutch down, start the engine and accelerate, then immediately swivel my foot to the brake (keep accelerating) and stand on it. Usually works within a cars length or so.
Alec
JPSmit todays's job - and a question Spridgets 25
JPSmit Todays question - wiring Spridgets 14
T TR2/3/3A Todays first Triumph 8
jlaird Todays strange question Spridgets 6
jlaird Todays tip Spridgets 4
JPSmit Todays adventure and happy news Spridgets 8
SilentUnicorn Todays History lesson British Motorbikes 2
TRclassic3 Todays electrical challenge Triumph 22
jlaird Todays question Spridgets 1
R From Tony Barnhills Obituary In Todays Newspaper MG 1
T Todays progress Spridgets 1
jlaird Todays tip, Carbs Spridgets 5
Brooklands As seen on todays Bring A Trailer British Motor Corp 0
jlaird Todays funny Spridgets 20
JPSmit Todays question - relays Spridgets 13
jlaird Todays plan Spridgets 7
JPSmit Todays Quirky Workhorse Cars? Other Cars 12
B Todays Minor Progress Spridgets 4
B Todays Progress Spridgets 5
B Todays Progress Spridgets 22
jlaird Did you know-todays trivia Spridgets 18
jlaird Todays mail Spridgets 1
jlaird Todays doings Spridgets 6
JPSmit Todays Paper - new MG Spridgets 14
jlaird Todays crazy question Spridgets 8
jlaird Todays question Spridgets 15
jlaird Todays schedule Spridgets 21
jlaird Todays fact Spridgets 4
jlaird Question- and todays is Spridgets 6
jlaird Todays story, shock Spridgets 3
jlaird Todays bits Spridgets 4
zimmy todays idle & pressure Spridgets 6
jlaird Todays ebay item Spridgets 1
jlaird Todays tip - Door hinges Spridgets 8
jlaird Todays question - brake drums Spridgets 7
jlaird Todays progress Spridgets 0
jlaird Todays question Spridgets 16
jlaird Todays effort, more later Spridgets 11
jlaird Todays question, fans Spridgets 12
jlaird Todays question Spridgets 6
jlaird Todays question Spridgets 3
jlaird Todays Question Spridgets 15
jlaird Todays dumb question Spridgets 2
jlaird Todays question Spridgets 4
jlaird Todays question, no lead head Spridgets 7
jlaird Todays question number II Spridgets 10
jlaird Todays extra credit question is... Spridgets 1
jlaird Todays question of intrest Spridgets 4
