TR4/4A Tire and wheel question
Kirk_Fisher
TR4 is being restored after the flash flood and it's time for new tires. There are not a lot of options for tires and I'd really like to get a wider wheel, so I can get much better tires and grip. Looking at replacing the wire wheels with the alloy wheels. Any recommendations on tires and tire sizes for these 15 x 51/2 wheels?
martx-5
I have 5 1/2" wheels (wires) that I put on my TR3. I got Vredestien Sprint Classics, 185/70-15 size. Not cheap, but they are great tires. That size will get you very close to the original diameter of the stock 165 tires.
KVH
195 65 15 Bridgestone was a great tire for me. Mine are Potenza, but if they don't make those anymore, I feel that size is perfect. Very close to stock, a bit wider.
JerryVV
205-60-15 give the same diameter as the original 165-15. My speedometer is spot on with this size. My first set were Bridgestone Potenza's, great tires but no longer available. The unfortunate part is there are not many choices for a performance tire in the 205-60-15 size. I ended up with Sumitomo's and they are OK but not Potenza quality.
Kirk_Fisher
Kirk_Fisher
I painted the wire wheels and they look pretty good, so I may stick with them for now. Really not much tire choice with the 165 though.
Geo Hahn
...Really not much tire choice with the 165 though.
Lots of choice would be nice but since one of the choices is 165/15 Vredestein Sprint Classics I really don't care what else I might have gotten. Fine tires.
I have seen much larger tires on stock rims -- including a local TR3 with 205s on them. Looked a bit like this -
url
rnpennington
I put on the Kumho ties from Discount Tire and have been happy with them. They are 165/80/15 and the price isn't bad 79.00 per tire. I use Discount Tire for all my cars - large network and - in my area - they will mount wire wheels. Not an option at a lot of places.
C
cpike
Wondering if anyone has experience with the new SilverstoneII 15 x 6 alloy wheels and the recommended 195-60 tires on a TR3A?
Kirk_Fisher
Kirk_Fisher
You are running wire wheels? 4.5 inches wide?
Kirk_Fisher
Kirk_Fisher
Leaning toward the Panasport wheels. Anyone have any issues with clearance with the wider wheel?
PAUL161
Summit Racing has Coker Firestones in 165/15s. I bought 5 for the MG TF at $88.00 each, including shipping. Nice tire with a period look. PJ
MHW
You shouldn't have a problem if you go with 5.5 wide wheels. I run 205/70 with 5.5 wide Panasports on my 4A, and I have no clearance issues. Here's a picture:
Geo Hahn
If you have clearance issues it will mostly be at full turn in reverse, possibly aggravated by whatever happens to the suspension as you come off a sloped driveway onto the street -- at least that what mine does. The interference is the front wheels contacting the upper wishbone. Contact is light but noisy nonetheless. I now have 3/16" spacers on the front and no contact under any circumstances. Alas, I do not recall the wheel width I am using, possibly more than 5.5".
S General TR Wire Wheel New Tire Installation Question Triumph 11
bugedd Wheel and Tire Question Spridgets 34
NutmegCT Stupid tire/wheel question. Triumph 18
69MGC Wheel and Tire question MG 3
prb51 BN6 Wheel/Tire Combo Austin Healey 26
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
AUSMHLY Wheel Tire Camber Austin Healey 57
Raymond MGB Wire Wheel Tire Mounting MG 0
6 Spitfire Tire bumps wheel well on spit mk3 Triumph 5
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
N Wheel and tire shopping. Spridgets 3
60TR3A What Size Tire is Ideal for a 15" X 5.5" Wheel? Triumph 29
L Wheel and tire sizes for the 3000 Austin Healey 8
T Wheel rim corrosion at tire bead contact Austin Healey 1
ekamm TR2/3/3A 3a steel wheel tire size? Triumph 14
HAN8L1965 Length of Steel Wheel Tire hold town Spridgets 7
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
mikecyc72usa Wheel and tire questions Triumph 11
M old tire & wheel Spridgets 9
W tire and wheel safety---pass it on! Restoration & Tools 0
T TR4/4A largest tire and wheel combo?? for a stock tr4 Triumph 10
glemon MGB MGB Tire and Wheel Sizes MG 14
ModifiedBJ7 Wheel Wells/Wheel & Tire Size Austin Healey 13
David_K HELP! BJ8 Wire Wheel/Tire Decision Austin Healey 11
angelfj1 Wheel/Tire Project Up-date Triumph 8
H Wire Wheel Conv in Albuq NM: Need a Good Tire Shop Austin Healey 4
H Wire Wheel Conv in Albuq NM; need a good tire shop Triumph 3
H 15 x 6.70 Size Tire Ok for 100-6 Wire Wheel? Austin Healey 3
KVH TR4/4A TR4 Wheel and Tire Sizes Triumph 3
H BJ8 wire wheel and tire size Austin Healey 7
Earl Wheel and Tire sizes Triumph 6
Mickey Richaud Wheel/tire Sizing Revisited MG 2
S Minilite Wheel and Tire Size Spridgets 3
R Wheel/tire bubble balancers MG 16
S TR2/3/3A Tire balance Triumph 15
J MGB Tire pressure for 1980 MGB MG 14
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
