zimmy
after talking to a few professional painters and alot of guys that drive MG midgets, ive come up with the failsafe total paint plan! here it is:
1.remove most everything removable in the painting area
2.sand entire car with 200 grit wet/dry
while also removing nicks, lumps, rust, etc
3.fill holes, dents etc with bondo, sand and repeat
4.paint repaired areas with primer, and fix all imperfections
with more bondo and sanding, prime as necessary to see imperfections....
5.sand entire car with 400 grit sandpaper
6.paint entire car with primer sealer
7.finally, ...paint the car, dry, repeat till desired finish
is achieved..
if i missed something or there is a problem understanding,
lemme know and ill update ...thx, hope this helps someone ..zimmy
is achieved..
