Stromberg carb question
KSROADSTER
Member
This may have been covered in "British car 1-01" But I think I must have skipped that day.........
Where is the oil in my dashpots going? I have one that goes dry in only a few miles of driving? I was using some 10w shock oil is that too thin? I have heard ATF works well. Any thoughts would be helpful. Thanks Bob
TR4nut
I think since your TR6 has carbs with fixed jets and adjustable needles - if so you are most likely losing oil past the o-ring seals in the needle assembly. Older Stromberg carbs had fixed needles and adjustable jets, with no oil loss issues but maybe the occasional gasoline leak. I had your problem on my Spitfire, I don't recall it being as bad as you describe though. I've also hear ATF works pretty well for the dashpots, it might be worth it to see if it slows leakage down for you. If not, I think a rebuild kit would have the appropriate replacement o-rings for the problem area in the dashpot.
Good luck,
Randy.
hondo402000
I had the same problem, I dont recall the Kit having this o ring. it also takes some effort to get the seal out, they have some kind of star washer that you push in from the top that secures the part in and you have to force it to get it out. I replaced the o ring with something I thought would work and still the oil drains into the carb and manifold. so if your smoking its the oil in the dampers. I went to webers and thats a whole nother issue
AltaKnight
Yep, leaking O ring is the cause and it doesn't come with the ZS carb overhaul kit (don't ask why), you have to order it seperately.
I use heavier oil in mine, like 20W30 engine oil, makes the mixture a little richer when accelerating since it dampens the movement of the air valve opening. The heavier oil might stay in the carb a little longer but there's really only one fix.
AlanT
The o-ring does come in the carb kit made by Royze but not the star washer (365-395) you need when you replace it. (I just refered to this part # in 'vendor rant' minutes ago.
Alan T
JPSmit Stromberg Carb Question Triumph 15
S Question on rebuilding Stromberg carb Triumph 24
T Stromberg 150 CD carb question Triumph 4
J TR4/4A TR4 Stromberg Carb Question ? Triumph 12
P GT6 GT6 stromberg carb question Triumph 6
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
H Stromberg Carb Sync and adjust Triumph 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
C Stromberg Carb 'O' ring Triumph 3
dklawson Improvising Stromberg Carb Tools Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
SCguy TR4/4A TR4 Stromberg Carb. adjustment Triumph 12
M Stromberg Carb Problem Triumph 5
S stromberg carb adjusting Triumph 2
Got_All_4 STROMBERG NEEDLES FOR 3 CARB SET UP Triumph 2
johnrip Zeinith-Stromberg Carb K+N Air Filters Triumph 8
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
