Strange electric problem.
JohnPal
1992 Jaguar Vandenplas (XJ6)
This morning whilst driving on my way to work the radio suddenly went out, and the fuse failure indicator came on. Pressing the VCM button on the dashboard, the "Fuse 1" error code was displayed. "Fine!" says I, "a blown fuse".
Checking the fuse circuit number 1, which is on the passenger side, I was surprised to discover that the 10-amp, number 3 fuse labeled "radio" was in perfect condition. In fact, I tested all the fuses in that fuse box, and they are all fine.
Now, here is the bizarre behaviour; The radio works fine with the ignition in accessory mode, but if I turn any of the interior lights, (dome light) it looses power. Opening the boot, the bonet, anything that draws power, causes the radio to turn off.
If I turn the ignition on (with or without the engine running) the radio dies and the fuse failure comes back on.
Any ideas? Could it be a bad relay?
Thanks in advance.
John.
equiprx
John,
I had a few cars come in the shop with bad wiring in the headliner for the visor lights. Good luck.
jessebogan
Hey Ex, did you get anywhere on the XJS w/ wiring issues? ( sorry for the hijack....)
LarryK
Since it seems to have a problem thru the ignition. Have you looked under the steering/wheel housing and dash to check for a loose ground. Pull radio and check the ground there too. If you have a 3' line to use as a tester, hook it to the back of the radio and a metal ground in dash and retest, do the same under steering wheel/column housing and do the same. Usually when something else is turned on and something looses power is a ground problem or crossed hot wire. Check grounds first. AutoZone, O'Riellys, Advanced Auto etc., sells a short circuit tester pretty cheap which can be used for the crossed wire check.
jessebogan
Oooops. That is what I get for trying to think when I am preoccupied.
J
JohnPal
Hmmm... Now that I recall, the problem started when I attempted to lower the driver's side sunvisor in order to mitigate the low, early morning sun.
Both the driver's and passenger's sunvisors have a small mirror with a light at each side. The mirror is covered, and the lights turn on when the cover is lifted.
If this should be the cause, any tips on how to fix it?
Thank you.
jessebogan
Has the headliner been replaced recently? Or have you had the visors off? I have seen screws put through the sunvisor harnesses cause all sorts of bizzare problems. Just for grins, check that all the connectors on the back of the fuse box are clean and tight. I see the occasional weird problems caused by loose connector blocks, or corroded pins at the back of the fuse boxes. You can take off the whole kick panel for access.
equiprx
Jesse,
Thanks for asking. I installed four 'super grounds' as suggested by Jaguar Bulletin but no joy. Have to leave it alone for a while. Got a bad case of the flu and don't do much of anything right now. Next time I get on a lift I need to check for exhaust leaks since the pipes look misaligned since the trans was rebuilt and vacuum leaks.
Steve
J
JohnPal
Halloween update; My Jaguar continues to be haunted. I removed the two sun visors and checked the cabling. They show no signs of damage and power is present (approximately 12 volts). I also removed the radio and reseated the fuse box (passenger's side) connections. However, the problem persists.
I've also noted these additional bizarre behaviours; with the ignition on, if I open the glove box door, the radio works. But, the radio looses power when I close the glove box door or turn on the headlights. Also, with the ignition completely off and the keys out, the AC fan turns on after about 20 seconds if the fan switch is left in low, high, etc.
I will continue to document this problem and the eventual solution in hopes that it will help someone down the road (pun intended). :p
Cheers... and Happy Halloween!
Platinum
These arbitrary on-off things are usually due to a bad ground someplace.
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
jlaird MGB Strange daily question. MG 10
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
Musicman Strange Clicky/Tappy Sound Triumph 6
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
racingenglishcars This is a strange one! Spridgets 9
angelfj1 I noticed something strange FORUM Navigation Questions 4
