MGB Strange daily question.
jlaird
Whitey my MGB with a V6 and auto tranny, GM of course needs to know if towing with rear wheels on the ground without unbolting the drive shaft will cause problems. I know that it must be disconnected for Spridgets, Keep in mind General Motors automatic tranny.
Snowing here in Tuckahoe NY again, hard.
Mickey Richaud
Discretion being the better part of valor, since it's an automatic, and since driveshaft removal is pretty simple, no question in my mind that the driveshaft needs to come out. Only other option is to trailer it.
Mickey
jlaird
jlaird
I towed a Bugeye ME to Atl on a dolly. Unbolted rear of the drive shaft and wired it up tight to body. No probs.
Mickey Richaud
That would work as well, Jack. I was thinking you were considering "4-down" towing with all wheels on the ground. Either way, the driveshaft needs to be disconnected.
jlaird
jlaird
Ha, no longer any way I can get under the car to bolt and unbolt the drive shaft. Guess I will just have to put in Air and Power steering and go for it.
JPSmit
I suspect, especially with Covid having the car shipped will be easier and more convenient in every possible way. Especially when the car is still in shakedown phase.
jlaird
jlaird
Sorry for the confusion. The car will be shipped for many obvious reasons. However I have a cabin in the mountains of NC with room for a MGB as well as my Acura and is only 2 1/2 hours from my home in Atlanta. Will have a grandson bring it up. He is in his early 20s.
Mickey Richaud
It will probably dump fluid if the prop shaft is removed?
If the shaft is just disconnected at the rear, it should be no issue. I don't know what auto trans is in there, but if the shaft is totally removed, there should be a plug/cap available for the transmission output, shouldn't there?
JPSmit
Changing the subject just a little, my most recent alma mater is in Decatur and our sister church has a retreat centre just outside of Asheville - one way or the other, when the world is a little more upside right, I would love to buy you a beverage and catch up in person - not to mention ooing and ahhing over the car (and maybe even in the car!)
:cheers:
jlaird
jlaird
Sounds like a plan.
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
Musicman Strange Clicky/Tappy Sound Triumph 6
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
racingenglishcars This is a strange one! Spridgets 9
angelfj1 I noticed something strange FORUM Navigation Questions 4
