Steering locked up
Slick Willy
I have been working on my wife's 68 sprite. Ive got the carbs and ignition done. Started the car all went well. I went to pull out of the garage but no steering! It will turn left and right about an inch each way. I checked nothing seems out of place or in the way. The car has set the last 2 years do to medical troubles. Ive done the clutch, fuel system and top end while it was down but it hasnt left the garage. Any ideals to what it may be? Or how to get it unstuck? Ive never had a car steering just seize up. Thanks for any advice.
Jim_Gruber
Did you mess with steering rack? There are shins in rack needed and without the correct thickness things will lock up.
SaxMan
The rack does have a zerk on the right side that you can try lubricating -- I believe it takes the same kind of gear oil that the rear diff uses.
If that doesn't work, did you mess with the trunnions at all? I know I accidentally put one on backwards. Besides giving the car a terrible amount of camber, I think it screwed up my steering, too. The other thing may be something stuck on the rack or the pinion?
Did the pinch bolt come loose where the column meets the rack?
LarryK
Put front end up and clean and grease fittings. There might be a zert on the rack body. Up in the air you can wiggle steering as you greas to see if it loosens up from sitting. You can also see if stops are adjusted correctly.
Joe Schlosser
A good inspection with it up on jacks is the first step.
My guess is it is not the rack but the swing axle/Kingpin upright. The rack does not tend to freeze up after sitting unless someone messed with it.
If it has been sitting for several years there is a good chance that the stub axles are semi frozen to the Kingpin/swivel upright. The grease can set up not allow the Stub axle to swivel on the Swivel to move.
I had this when I first bought my BE in 67, It had been sitting outside for a bit and the front end was semi solid.
As Larry said, jack it up and check out the grease fittings. If it is difficult to add more grease to the upper or lower fittings on the Axle the grease may have "set up"
You may have to pop the Tie rod end to find out which side is the problem. If it is the grease hopefully you can force enough new grease in to free everything up. If not you need to disassemble the parts and clean out the old grease.
AngliaGT
Locking steering column? If so,try the obvious -
turn the key while turning the steering wheel back & forth.
S
Slick Willy
Thanks guys, i havent messed with any of the steering. It has set, as ive been ill. Ive been out of town. But im gonna try dropping the tie rod ends to see what happens. I noticed it has a broken grease fitting on the kingpin.
S
Slick Willy
Turns out to be the rack. The driver side rubber gator boot busted and allowed water in. I took it out, cleaned it up and got it Steering again. Im gonna put new boots on for now and replace it later in the fall. I plan on doing the complete front end late fall. Thanks for the help guys.
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
W Steering Arm Colors Spridgets 1
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
Simmo TR2/3/3A Steering with Escort rack Triumph 5
