Steering Column Bushing
KVH
Whatever happened to those folks who were installing new steering column bushings with the "tab" protrusions--and trying to slide them into place?
I'm going to order new bushings myself and wonder what I'll be dealing with. thx
Mark_Gibson
Hi,
I just got finished replacing those column bushings and here is what I found to work well:
1. Use a small moto tool bit to remove the rubber tabs on the old bushings, be careful not to enlarge the holes they fit into.
2. Use a socket just slightly smaller than the diameter of the steering column with a couple of extensions attached to it. You can then gently tap on the end of the extension and the old bushings should come out.
3. Lubricate the outside of the new bushings, I used a very small amount of wheel bearing grease. You can reinstall the new bushings the same way, with the socket and extension trick. Don't remove any of the rubber tab material from the new bushings, they will slip inside the sterering column if you lubricate them. Just be careful that you don't push them past the tab holes. It took some time but it works! The nylon inner bushing is fairly delicate, so be careful tapping the new bushings into place. Hope that helps,
Mark
1970 TR-6
Walter74 Steering Column Felt Bushing Austin Healey 3
Retired2020 TR250 steering column bushing Triumph 2
L TR2/3/3A Upper steering column bushing Triumph 8
B Steering Column Bushing Austin Healey 2
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
mailbox Wedge Steering column bushing replacement Triumph 2
R TR6 steering column removal bushing replace Triumph 2
T TR2/3/3A TR3B steering column felt bushing Triumph 2
1965_MGB Steering Column Bushing Repair MG 3
X Upper steering column bushing MG 1
X Steering column upper bushing replacement MG 1
J Steering Column Bushing Removal Triumph 4
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
D Steering Column Adjustment Collet Austin Healey 8
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
