Splined hub thread dimension
jcsb
Wanting to check the pitch diameter on my 60 Healey 3000 splined hubs. While I know there 12tpi the od doesn't correspond to any other standard (ex. 2 5/16 or 2 3/8). Does anyone know the what the thread pattern is?
John
Keoke
SEE A moss or similar catalog there ate two different types course and fine it goes by car year
J
jcsb
Keoke,
I know that there 12 tpi, I want to know what size the thread is? I want to be able to measure the pitch diameter and I'm trying to get the basic thread dimension.
John
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
hondo402000 Splined hub set Triumph 5
K TR2/3/3A TR3A Splined hub extension picture? Triumph 4
jhva Splined Hub Tool Restoration & Tools 6
barneye TR2/3/3A TR3A Splined hub torque Triumph 2
R Bugeye splined wheels Spridgets 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
aero3113 Splined Hubs Austin Healey 17
aero3113 Splined hubs Austin Healey 2
J Rear splined hubs AH3000 Austin Healey 4
E question about splined hubs Austin Healey 13
hondo402000 splined wheel adapter kit to sell Triumph 0
NardisCNC Greasing Splined Hubs for Wire Wheels........... Spridgets 6
eschneider do they exist --- splined steel wheels [not wires] Other British Cars 15
G Splined Wire Wheel Hubs Austin Healey 7
mctriumph TR2/3/3A Hub cap emblems Triumph 2
D Removing the steering wheel hub Spridgets 12
Carlbanan56 MGB Front hub MG 4
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
B TR4/4A Steering Wheel Hub Issues Triumph 0
M T-Series MG TD 1st/2nd sliding hub end play MG 1
A BN7 Front Hub Stud Nuts Austin Healey 5
Lin Bugeye Axle Hub & Bearings Austin Healey 1
AUSMHLY Synchromesh Hub End Float Austin Healey 1
W Rear Axle Hub Seal Austin Healey 8
R TR2/3/3A Steering wheel hub removal Triumph 11
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
W Rear Hub Reassembly Austin Healey 7
A Later drum backing plates - hub not clearing Spridgets 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
K TR2/3/3A Front Hub and Felt Seal Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
M Spitfire Triumph spit flange/hub removal Triumph 13
Got_All_4 TR6 Differential side hub measurement Triumph 1
B Wanted Hub Austin Healey Classifieds 4
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
K For Sale TR3 Hub...short studs Triumph Classifieds 0
Rob Glasgow Rear Hub Nuts Austin Healey 11
B TR4/4A 3rd/top gear syncro hub Triumph 2
Sopwith_Camel hub of the action Jaguar 5
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
