Splined hub set
hondo402000
well I purchased a new splined hub set RFK1457 with the 2 eared knock offs, the set on my car are in good shape just a little rust, so I have a used set to sell, they have the octagon nuts, so if any one is interested send me a PM, so far fits TR4,4A, TR250 and TR6, 4 splines, 4 octagon nuts, wrench, and 16 wheel nuts
Hondo
Andrew Mace
Geo Hahn said:
FWIW -- also fits the late TR3s & all TR3As.
...and can be used to "upgrade" even the earliest TR2 to wire wheels or, with the right hubs, to replace unavailable worn original wire wheel hubs on the earlier "Lockheed" TRs.
They probably would fit the Stag and the 2000/2.5/2500 sedan range as well.
Geo Hahn
Though truth be told, I never cared for the 'safety' octagon knock-offs, guess it was because I remember rooting for Messala in that chariot race all those years ago...
TR3driver
Great Pumpkin - R.I.P
Are they unavailable? TRF had the fronts listed just a few days ago, although I didn't check the rears.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]They probably would fit the Stag and the 2000/2.5/2500 sedan range as well. [/QUOTE]
Yup, and the Stags at least had the safety knockoffs as original.
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
J Splined hub thread dimension Austin Healey 2
K TR2/3/3A TR3A Splined hub extension picture? Triumph 4
jhva Splined Hub Tool Restoration & Tools 6
barneye TR2/3/3A TR3A Splined hub torque Triumph 2
R Bugeye splined wheels Spridgets 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
aero3113 Splined Hubs Austin Healey 17
aero3113 Splined hubs Austin Healey 2
J Rear splined hubs AH3000 Austin Healey 4
E question about splined hubs Austin Healey 13
hondo402000 splined wheel adapter kit to sell Triumph 0
NardisCNC Greasing Splined Hubs for Wire Wheels........... Spridgets 6
eschneider do they exist --- splined steel wheels [not wires] Other British Cars 15
G Splined Wire Wheel Hubs Austin Healey 7
mctriumph TR2/3/3A Hub cap emblems Triumph 2
D Removing the steering wheel hub Spridgets 12
Carlbanan56 MGB Front hub MG 4
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
B TR4/4A Steering Wheel Hub Issues Triumph 0
M T-Series MG TD 1st/2nd sliding hub end play MG 1
A BN7 Front Hub Stud Nuts Austin Healey 5
Lin Bugeye Axle Hub & Bearings Austin Healey 1
AUSMHLY Synchromesh Hub End Float Austin Healey 1
W Rear Axle Hub Seal Austin Healey 8
R TR2/3/3A Steering wheel hub removal Triumph 11
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
W Rear Hub Reassembly Austin Healey 7
A Later drum backing plates - hub not clearing Spridgets 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
K TR2/3/3A Front Hub and Felt Seal Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
M Spitfire Triumph spit flange/hub removal Triumph 13
Got_All_4 TR6 Differential side hub measurement Triumph 1
B Wanted Hub Austin Healey Classifieds 4
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
K For Sale TR3 Hub...short studs Triumph Classifieds 0
Rob Glasgow Rear Hub Nuts Austin Healey 11
B TR4/4A 3rd/top gear syncro hub Triumph 2
Sopwith_Camel hub of the action Jaguar 5
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
