Spitfire spit rear handbrake cable won't come out
spit71
Member
Hello, I am in the middle of a rear suspension rebuild on my 1971 MKIV Spitfire. It didn't start out as a complete rebuild, but that's another story.
The driver's side rear bearings were so destroyed that the axle had to replaced. No problem, but I was accidently sent the longer one from a "74+. I decided that I might as well just switch to the longer ones on both sides since I would rather have those anyway, right?
I'm embarassed to admit that I was actually surprised to realize that my handbrake cable was no longer long enough.
One new '74+ rear handbrake cable delivered later and I CAN NOT get the old one threaded out of the car. The factory manual and Haynes is of no help.
I have removed all of the little clevis pin brackets and spring retainer tidbits off of the ends. The threaded end on the cable is too long to fit through the frame mounted "bend point" between the yolk and the end. This bend point has "eyelets" that the cable runs through at each end of the curved channel.
Does anyone know a trick to this? I am out of ideas. I try very hard not to lose patience and break something.
I am tempted to cut the cable, but I fear not being able to get the new one in.
Andrew Mace
I seem to recall that you'll have to get the end of the cable through one "eyelet" of the channel at a time. Alternatively, cut the end(s) off and use that same "one 'eyelet' at a time" philosophy to install the new cable. (It's easier to do than to describe!)
spit71
spit71
Member
Thanks, I'll try that. I was afraid to cut off the ends, but I guess that there's no turning back now, regardless.
Darwin
Bronze
Andy is correct. One eyelet at a time and even that can be a challenge. Take your time and don't be afraid to walk away or mutter to yourself while doing this project. I have had to insert and remove the cable several times during my rebuilding. It does get easier after a few tries.
spit71
spit71
Member
You are both, of course, completely correct. I had actually tried the one eyelet at a time strategy before posting, but was so frustrated by that time that nothing would work.
A little break, and some decompression time, and it was fine. The same applied to the reassembly of the new one.
Andrew Mace
Congratulations, from someone who's "been there, done that, got the t-shirt (and scars).... :smile:
Reh Spitfire GT6 rear shock to spit mount Triumph 3
K Spitfire Spit rear spring... Triumph 4
t_bush Spitfire Spit rear hubs, Arrrgh! Triumph 6
spit71 Spitfire Bad vibration in rear of '71 Spit Triumph 17
TR_Jim Spitfire Spit & GT6 Rear Spring Question Triumph 10
R Spitfire 78 spit: rear suspension woes Triumph 10
boeingpilot For Sale Parting out '75 and '76 Spit 1500s Triumph Classifieds 0
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
M Spitfire Triumph spit flange/hub removal Triumph 13
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
D Spitfire 1975 Spit resurrection Triumph 4
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
B Spitfire Parting out 67 Spit Mk3 Triumph 1
D Spitfire MkI Spit questions Triumph 9
AEW Spitfire vintage racer replica on Spit running gear. Triumph 4
T Spitfire Free early Spit in Boise Triumph 1
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
glemon Spitfire Craigslist Spit Triumph 2
G Spitfire Anyone ever see a Spit look like this one? Triumph 5
tr6nitjulius Stag TR3*4*6*7*8*Spit*GT6*Stag=20 [pics] Triumph 0
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
This14u Spitfire Pic of Spit A-Pillar Details Triumph 3
D Spitfire MKII cam in a MKII '65 Spit - pros and cons Triumph 2
D '65 Spit heater control valve Restoration & Tools 1
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
TonyPanchot Spitfire Spit Windscreen trim Triumph 3
6 Spitfire Tire bumps wheel well on spit mk3 Triumph 5
K Spitfire Door striker 63 Spit Triumph 1
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
G Spitfire Bought a Spit today, a bit bummed out Triumph 12
G Spitfire Spit Hardtop $50! Triumph 4
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
O Spitfire Spit 1500 Thrust Washers? Triumph 13
This14u Spitfire Clutch Slave Access on Late Spit Triumph 0
doates Spitfire Why Doesn't My Spit Sit Level Triumph 8
B Spitfire Advice on Muffler for 69 Spit Triumph 5
B Spitfire big bearing snap rings on Spit single rail Triumph 0
Dudly Spitfire steering wheel for 79 spit Triumph 1
Dudly Spitfire Blowing fuses in my 79 spit Triumph 10
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
M_Pied_Lourd Spitfire Low Mileage Spit Triumph 3
B Spitfire 1500 SPIT OD ELECTRICAL Triumph 1
doates Spitfire Spit was running great Triumph 17
