Runs good...starts missing...and then..
livinginthepast
...starts running good again!
So I'm driving the BE this morning and as I'm waiting at an exceptionally long light, the engine starts missing. I had to step on the accelerator a little to keep it running. I drive about a quarter of a mile (I was close to home) and like magic, it starts running smooth again.
I get it home and do some quick checks...all *seems* okay. Check the plugs - running a little lean (which doesn't surprise me - it has been lean for a couple of weeks now, after playing with different needles in the carbs). So I turn the adjuster nuts out a flat or so, close the bonnet and go out for a drive around the neighborhood. All remains normal.
Any guesses on what may have cause the missing?
Thanks!
jlaird
It could be many many things. I could list stuff for you to check forever, most of which I have had happen to me.
Give it a go again and see if it was just a carb to lean.
davester
As Jack inferred, this could be a very long list. My suggestion is to live it up since it seems to be running fine now.
jhorton3
I've had that happen to me sitting at traffic lights after a good run. I think mine was a condition of pressure regulation, and to some degree a bit of vapor lock because the fuel supply lines may have been a little too warm.
Sarastro
Well, if it keeps working, then there's no need to go further. My gut feeling, however, is that this will happen again.
I've had this problem, but much worse. Here is my story of it, and what I did about it. Might be useful if the problem persists.
JPSmit
one other possibility might be crud in the line or in the tank
livinginthepast
livinginthepast
Thanks all. It ran fine today, but then I only drove it a couple of miles.
Steve - I'll review your story. My gut tells me I haven't heard the last of this... :smile:
livinginthepast
livinginthepast
Is there any chance this is connected to the generator in some way?
I ask because I noticed the tach making noise again today - this time I can hear it coming from the generator - not behind the dash. Just a tick-tick-ticking. I also noticed that the tach is not reading correctly (engine sounds like 2500rpm..but reading 4000, idle reading at 1500, but the multimeter reads about 700 rpm). The engine continues to run relatively well, but given everything, I'm wondering if the tach/generator issue may be connected to the engine mysteriously running rough and then fixing itself.
Thanks!
jlaird
Sounds like it is time to lub the tac cable, might as well do the tac gear box while you have it apart.
I had a similar problem starting my car up the other day. turned out to be a sticky float.
m
Sarastro
I doubt that the tach problem is related. It sounds like the tach is just sticking a bit. The cup and pointer part is pretty delicate and easily starts to drag or stick. The little watch spring it uses might have come loose; that's another possibility. If you're good at mechanical work with small parts, it's not hard to take it apart and clean and lube everything. The alternative is to get a new one on eBay, where they go for $30-$50.
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
2billydavies TR2/3/3A runs excellent but starts hard after use Triumph 8
Westfield_XI MegaJolted 1380 starts and runs Spridgets 6
kindofblue It Starts, and Runs, and Runs on!!! Triumph 4
M TR6 TR6 starts, runs, then dies Triumph 5
Bayless Onslo the Sprite runs Spridgets 4
B TR2/3/3A It runs, again Triumph 3
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
M Midget runs inconsistently Spridgets 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
F TR6 1975 TR6 runs lean Triumph 11
FlyingCat Spitfire Runs, but not well Triumph 26
B Fuel pipe runs BJ8 Austin Healey 2
D TR2/3/3A Alternator dial runs high Triumph 5
D Its Runs! Spridgets 6
D Lilly test runs Austin Healey 4
C runs better without air cleaners?? Austin Healey 19
KVH General Tech TR4A Runs Terrific Triumph 2
Tinkerman TR2/3/3A It runs! Triumph 8
B T-Series 51 td runs rich MG 17
Gundy Runs a bit...then quits Spridgets 18
HealeyRick Runs a Bit - Then Quits Spridgets 23
K Hard Start, runs poorly when cold Spridgets 10
gbtr6 TR6 Help! Starter runs with ignition in on position Triumph 18
drooartz MGB-GT It runs! MG 6
C Ship deliberately runs aground carrying Jaguars and Land Rovers, but why? Jaguar 0
M TR6 TR-250 CC engine runs great, then nada, wait > 2 days, then runs great again, repeat Triumph 7
B Everything runs better with this mod - all models!!! Spridgets 7
DanLewis Runs on 3 cylinders at idle, but all 4 at higher rpms??? Spridgets 25
D TR6 Blower runs off and on Triumph 4
N Runs Rough Under Load Spridgets 15
Sarastro T-Series It runs! MG 8
R engine runs cool Austin Healey 16
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
martin_burtt TR6 TR6 - runs but no power under load? Triumph 11
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
T She runs! She won't stop running! Triumph 2
C '72 Midget Runs On 2 Cylinders at Highway Speeds Spridgets 73
N After 30 years, it runs! Austin Healey 7
S TR2/3/3A TR-3 hard to start, but runs well once started Triumph 5
G Well, it runs and drives Triumph 5
V Fuel pump runs continuously! Spridgets 18
livinginthepast After a long winter's nap - BE runs around town... Spridgets 7
Wizardd MGB '77 MGB runs for a bit, then shuts down MG 28
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
C My car runs unevenly...... Triumph 4
DART IT RUNS!!!!!!!! Other British Cars 3
jlaird New. She runs but. Spridgets 7
mikecyc72usa Finally, it runs! Triumph 8
