Retractable Seat Belts
SaxMan
Last year, I decided to upgrade Baby Blue's seat belts to retractable units, mainly because of the way my daughter moves about in the car while we're driving. I ordered a pair of retractable units from VB. Installation was a breeze, as I just mounted it directly to the rear wheel arch. However, the biggest problem I'm running into is that the one on the driver's side jams / inertia locks without any rhyme or reason. I can usually get it going again with some finagling and effort. I have it set up identical to the passenger side in terms of where all the arrows point, etc. Is this unit just a lemon, or am I missing something in the setup?
Jim_Gruber
It's the angle belt is positioned at. The reel works via gravity. Tweak the mounting angle just a smidge and you should be able to get it to work.
S
SaxMan
Thanks, Jim! A little bit of tweaking seemed to do the trick. I don't think it likes the angle from the retractor to how it goes over the top of the bucket ('69 had the unique bucket seat / headrest combination). I mounted directly to the wheel arch instead of using a bracket. I figured less bolts between the retractor and the body would give it more of a chance of doing what it is supposed to in an accident: keep me from eating the steering wheel.
Jim_Gruber
Glad I could help
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
Lotuswins BJ8 3 pt retractable Seat Belts Austin Healey 10
7 Retractable seat belts - BT7 Austin Healey 8
T How did you mount your retractable seat belt? MG 6
I TR6 TR6 retractable seat belt source? Triumph 10
Jim_Gruber Retractable Seat Belt-Mine has been eaten Spridgets 3
Michael Oritt Retractable two-point seatbelts Austin Healey 12
brgrmyster Kangol Reflex retractable seatbelts Jaguar 4
G Fully retractable radio antenna Triumph 5
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
