Replacing Michelin Red Lines....a question
bricktop
I am interested in upgrading the tire technology on my 6. I am running the original michelin red lines but I understand that there are also "red lines" available that are a more contemporary version of tire technology...may or may not also be made by Michelin. Any truth to this and if so, where might I seek such tires? I really prefer the look of the red lines to any other tire I have seen on a 6, but I am seeking a newer version of the classics. Anyone?
DougF
I would agree with you on a technological upgrade. Redlines, wet roads, and speed have caused many a TR6 an early trip to the salvage yard.
I can't answer who is producing the tire you are refering to, but I seem to remember that being true.
Another option is to buy the tire you want and have a tire store put a redline on it. I know British Car Magazine had done this years ago to a car. I do not know the longevity of the stripe, but it could be something to research. In the photos, it looked better than a plain painted stripe.
G
Or, www.classicalpontiac.com/restoration/8.html
There are some more modern "redlines" on the market that are
radials, unlike the original Michelin Redlines.
I know of more than a few guys who want the original redline look for shows. They will use the original steel Triumph wheel, paint it to perfection, mount a set of original redlines (tubes and all) and store them for shows. (Coker Tires)
They will run modern radials with aftermarket wheels, such as Panasports, and enjoy their car to its fullest potential.
Original redlines are great fun, on dry surfaces, below 55, during the daylight hours, on Sundays, above 75 degrees....
You get the point.
Bill
Andrew Mace
[ QUOTE ]
radials, unlike the original Michelin Redlines....
[/ QUOTE ]There's no question that the original Michelin X redlines WERE radial tires, but they were maybe "2nd generation" at best...and there have been many generations since!
G
You are correct, Andy, but the fact that they required tubes sure made them act like biased tires. They were pretty bad. I currently have 205/70R15 Michelin Hydroedge tires on Panasports and they stick like glue in all weather conditions.
Andrew Mace
Pretty bad? No question! Sure, they were better than a Goodyear Custom Power Cushion or Dunlop Gold Seal, but they can't hold a candle to almost any radial produced today! Thank goodness tire technology has improved, eh? /ubbthreads/images/graemlins/laugh.gif
vettedog72
Did any one thry the red stripe Goodyear that also was OEM on some TR6's. I had one as a spare, looked near new and had much more agressive tread design. I have never seen a contrast of the two brands.
B
bricktop
Thanks, interesting article. My wife sees me handpainting a stripe on each tire and she'll think I've finally lost it. Ha!
G
[ QUOTE ]
[/ QUOTE ]
Explain to your wife that because we can't give birth, we have to use our creative instincts by restoring cars.
(plagerized thought)
Bill
Andrew Mace
[ QUOTE ]
[/ QUOTE ]The Goodyear G800(S?) has been gone for many, many years. People tend to forget that the Goodyear was actually THE OEM tire for the most part (with the possible exception of cars equipped with wire wheels, as I don't recall Goodyear made a "tube" version of that tire). A 155SR13 version was also OEM for several years on the GT6.
I don't recall any comparisons ever between the two, but I agree that the Goodyear tread pattern was more aggressive-looking....
bobh
My '71 TR6 had the original Goodyears when I bought it in'73. They were shot by the time I hit 20K miles. Over the years we put a couple of sets of Goodyear tires on various cars. None of them ever lasted very long. Always less than 20K. Haven't used and of their tires since the early '80s.
kodanja
So what tire in your opinon give the best and most comfortable ride for a TR6?
swift6
If your actually driving on the original tires STOP. They are way to old to be safe. /ubbthreads/images/graemlins/nonono.gif You are putting yourself, your car and any who might be with you or on the road with you in danger anytime you drive the car. Even cheap Costco tires are years ahead in technology, grip and ride comfort than the original tires that came on these cars. Please don't endanger lives for the vanity of having original tires. If they are original style, but newer, then I'll get off my soapbox. /ubbthreads/images/graemlins/hammer.gif
kodanja
[ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif A buddie of mine was driving his MGB GT on the original tires and had a blowout at 65 mph. He broke his arm, Thank God he's is ok but the car got totalled & luckly no one was near him on the road....(DRY ROTS A KILLER)! /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/england.gif
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
T TR4/4A Replacing Drive Train Seals Triumph 5
