TR6 Replaced steering rack in my TR6- very twitchy now
71TR6
I replaced the factory steering rack in my TR6 with a 3.5T Bastuck rack and have a question for the forum. I notice the Bastuck rack is very twitchy. I am wondering whether this is the nature of these racks or is it just that it is new and not worn like the old one. Driving down the road feels like balancing on a marble to keep the car going straight. The car was professionally aligned after I installed the rack.
Has anyone else experienced this with an aftermarket Bastuck rack?
Ron
PAUL161
Have you checked the tow-in? I've seen this happen on some cars with no tow in. My TF was quite sensitive until I added 1/8" tow in and the twitchiness disappeared. PJ
bobhustead
In order to make a car want to go straight, something in the three planes of steering geometry needs to be in a non-neutral but steady position. If you have worn parts in the suspension, out of whack toe in may be the factor that put your system into non-neutral territory. i.e., incorrect toe in was compensating for misalignment of worn parts somewhere else. When you put the toe in right, the geometry can go neutral or allow a sloppy joint somewhere to suddenly take up slack when you turn the wheel just a little bit.
PAUL161
I'm not a TR guy, but the Bastuck steering rack has very positive reviews and is reported to have a slower reaction steering than the original setup, plus the guys seem to like it. I would check to make sure all your linkages are tight with no slack and again add about 1/8th inch toe in to start. JMHO. PJ
71TR6
71TR6
Thanks everyone! To clarify, do I adjust the toe in so the tire to tire distance of each tire is in by 1/8" total or does each tire get adjusted in by 1/8"? I just want to be clear where and how the toe-in is measured in this case.
Ron
mezy
measure from the centre line of the rims not the tyre from inside edge to inside edge back and front of the wheel, the front need to be shorter than the back, hence tow in, unlike front wheel drive cars that toe out.
71TR6
71TR6
Thanks Mezy. So is the 1/8ā€ total toe in ( move each wheel in 1/16ā€) or do I move each wheel in 1/8ā€ for a total of 1/4ā€?
Ron
mezy
Ron
it is the total amount, but i think it is 1/16" but you will need to chack the vehicle specs to be 100% sure,
too much toe in will cause tyre ware on the outside of the tread
Sbardon
Ron
Ron, it sounds like you are on the right track,.... but back to the beginning... sometimes Alignment shops pump up the tires rock hard... 40+psi for setting the alignment. Did you check the tire pressure after? my 6 is is beyond twitchy, it is scary and drives like on ice, with the tire pressure at 35+ instead of the 20, Just a thought.....
mctriumph
Malbaby is spot on. find a good alignment store and get the full reading all round. If you have any
questions , remember all readings should be in the green when finished.
Mad dog
tr6nitjulius
Perhaps what you consider twitchy is responsive. R&R OEM rack several years ago for hi-ration quick rack aka racing rack. Eliminates full turn lock to lock: OEM 3-1/2 turns hi-ratio 2-1/2 turns. Realized how much unnecessary slop/movement/corrections required while driving down the road with OEM rack even rebuilt.
Trade off hi-ratio is very responsive 1/8 turn of wheel is a lane change where as OEM 1/4 turn,. Gave 2 fellow TR6 owners a ride on roads they were familiar with both heard hi-ratio would be too twitchy both impressed after the ride with less effort to turn, mounts adjustable to make steering responsive to suit
J has anyone ever replaced lower bushing in steering Triumph 5
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
Basil Replaced Telluride Reverse lights w/ LEDs Other Cars 7
T 66 Austin Healey fuel pump replaced Austin Healey 30
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
M Brake fluid on tire - cylinder need replaced? Spridgets 19
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
T GT6 These sills have been replaced, correct? Triumph 7
Michael Oritt WT/OP gauge replaced/plus a hose Austin Healey 0
PAUL161 MGB Replaced sending gas gauge unit. MG 5
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
B TR2/3/3A When you replaced your wiring harness [57 TR3] Triumph 5
M Replaced rear end, can't reconnect propshaft Spridgets 2
1 Rims need to be restored and/or replaced MG 19
jlaird Replaced that darn hose today Spridgets 0
Monark192 No Power - replaced coil, wires, rotor and cap MG 3
T TR2/3/3A Another TR3 battery box replaced Triumph 5
R 61 BT7 fuel tank needs to be replaced Austin Healey 14
RickB Replaced my alternator today. Spridgets 17
Randy Harris OT - Finally replaced my daily driver last week Austin Healey 11
T Should floor pan be replaced? MG 15
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
S Wedge TR7 sender replaced...but still sweeps to hot Triumph 23
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
