remove a vent window
Woodie
That is my question today. The 2 screws and spring under are undone, the 2 screws on the leading door frame are undone. It won't budge. What am I missing?
The bolt at the bottom of the window track.
thanks guys,,, so JP Bolt B is a guide that keeps the window track straight,
besides the bottom of the vent window track what else is attached to bolts "A"
looks like a 5 minute job....
A is only the bottom of the window track. I can't remember just off the top of my head but one of the tracks (I think the front) the flange (that the A bolts bolt onto) is removable from the track itself so you can slide the track out the hole - does that make sense?
B actually seems to force the track to curve. It's more of a "stop" than a bolt - in other words, it's not attached to the track itself, only the door.
not a hard job though you may need to loosen the rear track a little to make room for the track to slide out
ok so should the window be up or down to undo these two bolts? and once undone, then the vent window simply lifts out?
Sorta glad I don't have ANY side windows to deal with (other than side curtains which, to be honest, don't fit for diddly).
I got mine loose, they pulled about 3/4 of the way out, but not all the way out. Never quite figured out how to completely remove them without taking out the window glass also
I think you may have left the bottom bracket on - It's not really designed to come out without the window, but as I recall, it's doable
well I took out the bottom 2 bolts . That allowed the window to be lifted enough so that I could get the old rubber stip out and the new one in. It really is only a 3o minute job, to change the weather stripping on one door, start to finish. Thats how long it took to do the passenger side. Knowing what to do makes things so easy....
I think I will need to have a midget until I am to old to drive. I almost know how to fix everything.
My 87 yr old father and his girlfriend came by today. They bought a new Hundyai elantra. Nice car, but I told him don't come to me to fix anything other than add windshield fluid. The engine bay was clean, but I did not recognize anything except the rad....
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
drooartz Bugeye jack points to remove rear axle Spridgets 18
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
C How to remove temp sensor at block? Austin Healey 16
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
