TR4/4A Rear Seatback/Hoodstick [Top] cover install
TeBock
TR4 Rear Seatback/Hoodstick cover install
I'm in the process of rescuing a 1962 Triumph TR4. I'm installing the interior trim (Moss Panel and Carpet Kits) but am not sure how the "Rear Sewn Seat Back" is installed. I've contacted Moss but they can't find any details as to how this rear seat back/cover (and rear valence covers) are installed. These pieces serve as the hoodstick covers on a soft top TR4. It kind of, sort of, seems as if these pieces fit under the moulding trim pieces. But are they also glued down, or weather-proofed in some fashion? Or is there some other method of installing? The edges of the upholstery consist of leather, foam and fabric layers. Is the pressure of the moulding enough to keep water from seeping into the foam layer and further into the seat back? Should it be sealed in some fashion? I had a TR4 50 years ago but have no idea how that seat back was installed. Took it for granted ... and this one came with an upholstery-less interior, leaving me scratching my hair-challenged head. If anyone with a soft top TR4 could look at that back seat and tell me how it is attached, my wife will be forever grateful (me too).:smile:
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
